383 stroker setup
Old Oct 22, 2005 | 08:23 AM
Default 383 stroker setup
OK well i'm pretty much ready to swap my stroker engine into my truck, i 'm wondering what everyone thinks about running this cam in it for a little while. its the MTI b1(maybe) anyways the specs are 221/221 .558/.558 114+4. its the one in my truck right now actually. i will be using 241 heads, milled .015 that are ported to stage 1.5 using stock valves and 918 springs.
any suggestions or opinions?
other info...
eagle 4inch crank
eagle 6.125 h beams
ross flat tops with -2cc reliefs
Old Oct 22, 2005 | 08:26 AM
bluecajun5.3's Avatar
11 Second Truck Club
i think that's a good cam to start with. should give you lots of bottom end, mid, and top. let us know what kind of power that thing puts down and 1/4mi times. nice setup!
Old Oct 22, 2005 | 10:22 AM
jerome's Avatar
if youre doing an all out setup that might be a little small, but if youre doing the work yourself it doesnt matter, just slap it in there and change it out later if you want more
Old Oct 22, 2005 | 01:43 PM
thats what im thinking, since i'm doing it myself, i can easily swap later down the road. i was just trying to get an idea of what the driveablitly would be like, since i've never driven something with a big cam.
Old Oct 23, 2005 | 03:44 PM
silverado's Avatar
Driving a truck with a cam thats too big sucks! (I've done it) If you want more later on you can always switch em out, but with the weight of a truck you can really feel the low end loss that bigger cams come with!
Old Oct 24, 2005 | 08:45 AM
[QUOTE=silverado]Driving a truck with a cam thats too big sucks! (I've done it) If you want more later on you can always switch em out, but with the weight of a truck you can really feel the low end loss that bigger cams come with![/QUOTE
what are the cam specs on your 383?
Old Oct 24, 2005 | 10:36 AM
gonzo 6.2's Avatar
I would say that maybe a near perfect cam,what compression ratio?
Old Oct 25, 2005 | 10:57 AM
compression will be around 10.7-11.4:1
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
jtphelps289
Sep 11, 2015 06:37 PM
