370/MP122 Build
Old Apr 20, 2007 | 05:52 PM
  #31
dhpro's Avatar
Originally Posted by Holty
so your putting a mp112 on a 370?
the oil pan looks good as hell, can you make me one too? the head covers direct bolt on and will accomodate all the coils and factory clips, connectors, etc?
Nope...MP122H going on...the 112 was on the 5.3L. Pan is a Moroso...nice piece, but its gonna need some work done to it. Head covers will need some custom gab for the coils and all. I was actually gonna try and move them to the firewall, or somewhere else to leave the covers visible...R/
Old Apr 23, 2007 | 05:05 AM
  #32
BADMOFO's Avatar
Cuz I AM a BADMOFO
There is no way I'd mount the coils to those valve covers. I'd want them to be shown in their full glory
Old Apr 23, 2007 | 06:11 AM
  #33
dhpro's Avatar
Coil mounting suggestions are welcome!
Old Apr 30, 2007 | 07:38 AM
  #34
dhpro's Avatar
Default PIX Updated...again!!
More pix up to date. Pan was altered for clearance, header clearance good, MP122 & Motor installed. E-Fans hooked up.
Problems: Speed kit was sent with the 2wd cross-member instead of 4wd, so had to do some alterations for the actuator module to fit. they also didn't send the new dip stick, AND the rear drive shaft is now too long. When I ordered the kit I enquired about exactly that and was told all wud fit with the new shaft and fittings they provided ...oh well, shud be fixed by now!
Thinking of wrapping the headers while we're at it - anything to keep underhood temps down!
Left to do: locate remote oil filter and cooler with -10AN spec, and remote coil packs - SUGGESTIONS WELCOME!
http://s167.photobucket.com/albums/u138/dhpro/
Old Apr 30, 2007 | 09:02 AM
  #35
BlownChevy's Avatar
blownerator
25 Year Member
Great work Randy!
Old Apr 30, 2007 | 10:21 AM
  #36
Bill Reid's Avatar
Awesome work!
Fluidyne and Earls makes some real nice oil coolers for -10 fitment. What I haven't determined yet is what size is necessary. My requirements may be a little different than yours because I will have a turbo heating up my oil... and I live in Arizona. Right now I'm thinking the biggest cooler... but DAYUMN are they expensive.
I have seen the coils relocated to the engine block (believe I saw it on LS1Tech)... feeding the wires straight up to the plugs but not sure if custom wires were used. I like the covers you have. I also like Abear's... which would not require coil pack relocation.
FWIW, I recommend coating the headers before wrapping them.
Old May 1, 2007 | 02:17 PM
  #37
LQ4_TRUCK's Avatar
Registered User
you can test it out in my truck.
Old May 7, 2007 | 06:31 AM
  #38
dhpro's Avatar
Up and running!!! Tranny and all...had oil pressure problem as it was a little lite, but seemed to be a faulty pump. Can't wait to abuse my neighbors! Shud have more pix soon, and maybe a video by the weekend...I shud know more by later 2day.
Old May 7, 2007 | 11:13 AM
  #39
rgarzajr's Avatar
ohh **** that looks brutal
Old May 7, 2007 | 11:46 AM
  #40
Mr. Sandog's Avatar
Still have the 10-bolt in there?
