370 build advice or thoughts welcome!
Old Oct 7, 2006 | 08:54 PM
  #71
litreddevil's Avatar
Banned
Originally Posted by TurboGibbs
Small ported heads?
Not taking the time to port mine. I figure i'll have plenty anway.
the heads i have are already ported i am just milling them a little more to get more compression in february i am putting the l92 heads intake 90mm tb and a turbo
Old Oct 7, 2006 | 09:53 PM
  #72
2004SSS's Avatar
well the motor is starting to come along just getting all of the parts, i have ported and polished 317's(cnc) dual springs, eagle rods, probe pistons, and im sticking with the iron block, the part im having trouble with now is do i buy the forged 3.622 or stay with the stock.
Old Oct 7, 2006 | 11:49 PM
  #73
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I would recommend a forged 4" stroke over a forged 3.622 crank because the are very close to the same price.
Old Oct 8, 2006 | 01:09 PM
  #74
2004SSS's Avatar
well the ting is i already have a cam for a 370 and i dont feel like selling it and orderign another one. plus i know the added torque from a 408 will kill my tranny even faster. so 370 plus boost it is most likly going to be.
Old Oct 8, 2006 | 05:27 PM
  #75
Stoichiometric's Avatar
What is the cam that you currently have? Small cams can work very well with turbo's, I think the added displacement will help get you spooling faster.
Edit: Sorry I didn't realize you run a blower, in that case the displacement obviously doesn't affect "spool".
Old Jan 11, 2007 | 01:48 AM
  #76
2004SSS's Avatar
well im finally on my way, i took the engine out last night with 12-13 psi. didnt sound good and alot of smoke. so i ordered the crank today(eagle 3.622) im going to use forged probe rods( like moregrip) and most likley je pistons. im using patriot stg 3 heads , a 216/222 546/587 114 +3 cam. and im going to use most of my stcok stuff if its ok. i may go with some new rockers and new timign chain . hopefully i get his done fast so i can drive the SS again. i want to throw 15 psi and 150 shot at it. can you say 7 k shifts!!
Old Jan 11, 2007 | 09:57 PM
  #77
1slow01Z71's Avatar
I still think you should have saved your money on a forged crank, the factory crank has been proven to 1000rwhp.
Old Jan 11, 2007 | 10:41 PM
  #78
'89ChevyMadneSS's Avatar
Old Jan 12, 2007 | 12:11 AM
  #79
2004SSS's Avatar
i got a good deal on it, and i dont want the heart ache if somethign goes wrong. its also lighter so it will rev up faster , i know not much i just need this engine to handle 1000 hp. besides im 99% sure my stock crank is trash. i know i have a big hole in the side of my 5k mile old lq9. i dont see it as a waste i see it as insurance.
Old Jan 12, 2007 | 06:15 AM
  #80
TurboBerserker's Avatar
I AM A MOTHERF*CKER
It's never a mistake to do something right the first time.
BTW... I just remembered this same conversation from 9/06 in this thread:
Originally Posted by turboberserker in Post #28
Chase if you're still looking for 17psi + n2o, go forged everything as Sled recommended.
Seeing one or two cars hit 1000 hp with a stock crank does not "prove" the crank can withstand that. Showing a thousand of *trucks* do it, daily driven as Chase's truck will be, and for 50000 miles with n2o and 17psi for track duty may start to get there.
There is no harm in over-building. There's a lot of heart ache (and broken parts) in under-building.
We get that you think the stock crank would have been enough Cody. We just don't agree. There's no reason to keep banging that drum, ok?
