370 build advice or thoughts welcome!
Old Sep 11, 2006 | 12:05 AM
  #51
04Denali's Avatar
Originally Posted by kbracing96
Ya, I belive Speed Engineering makes an output shaft for a 80 that will mate into the AWD TC.
I was going to say speed engineering also but I only heard second hand that they do it, But chuck told me personally.
Mark
Old Sep 15, 2006 | 01:07 PM
  #52
2004SSS's Avatar
so would there be any idsadvantages in using the ls2 block , its not that much more expensive and if it will save some weight im game. how hard is it to relocate the knock sensors??
Old Sep 15, 2006 | 01:15 PM
  #53
TurboGibbs's Avatar
There is a sponsor on tech that makes an extension harness. Do some searches in the LS2 engine section. There is a lot of info there on differences etc.
Old Sep 15, 2006 | 01:28 PM
  #54
SLED28's Avatar
FormerVendor
go ls2 block all the way! I sell plug and play harness's (two) for the conversion. They are 55bucks
Old Sep 15, 2006 | 01:44 PM
  #55
TurboGibbs's Avatar
Yeah! That's the guy!
Old Sep 15, 2006 | 02:08 PM
  #56
vanillagorilla's Avatar
You have to run a different timing chain setup too because the cam sensor is in a different location.
Old Sep 15, 2006 | 04:25 PM
  #57
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
and change the reluctor ring to a 24 tooth
The L92 crank is supposedly shipped without the reluctor seated on the crank.
Old Sep 15, 2006 | 05:34 PM
  #58
litreddevil's Avatar
Banned
i am get my motor builded right now and it is going to be a 370 ci and it is getting diamond pistons and ls1 crank and lq9 rods with a set of small ported heads and when all done alot of spray
Old Sep 15, 2006 | 05:52 PM
  #59
TurboGibbs's Avatar
Small ported heads?
Not taking the time to port mine. I figure i'll have plenty anway.
Old Sep 19, 2006 | 12:09 AM
  #60
2004SSS's Avatar
well , now im probably going to use the ls2 block, i see you guys mentioning i need a new cam gear , or do i need a new timing cover?, also how exaclt do i get the stock knock sensors to work on the ls2 block? what exaclty will i need to chane with the swap?? will the stock oil pan work with the ls2 block??
