370 build advice or thoughts welcome!
Old Jan 12, 2007 | 08:30 AM
  #81
vanillagorilla's Avatar
Old Jan 12, 2007 | 10:14 AM
  #82
dhpro's Avatar
Originally Posted by 2004SSS
i got a good deal on it, and i dont want the heart ache if somethign goes wrong. its also lighter so it will rev up faster , i know not much i just need this engine to handle 1000 hp. besides im 99% sure my stock crank is trash. i know i have a big hole in the side of my 5k mile old lq9. i dont see it as a waste i see it as insurance.
I have a used stock crank I was gonna use as well, and I'm toying with the Eagle crank instead. I'm putting RHS proaction heads (66/236) and Diamond pistons...prob use eagle rods. Still have to pick valves springs, rollers and pins. Cam is custom 214/218 559/562 114 lobe (kinda lumpy ). Lemme know how u do as this is the set up that Maggie and Brian are so bullish on. I was thing of a 100 shot, but prob save it for a later date...
Good Luck! R/
Old Jan 12, 2007 | 10:33 AM
  #83
dhpro's Avatar
The biggest issue for me is tranny. 4L60-65 is definately not gonna hold up reliably, so 4l80 conversion is the ticket. prob is that Speed-eng doesn't take phone calls, and I've read a few -ve threads about their products and service. Traded a few PM's with them, but they didin't go out of their way to increase my comfort level. I think I cana ssemble the majority of the parts with a little research and get my local tranny guy to do the rest of the work for better than half what speed wud charge....anyone with parts and part #'s pls feel free to chime in!
Old Jan 12, 2007 | 01:12 PM
  #84
2004SSS's Avatar
i think my 65 is doing ok for now. i will find out once i hit it with the boost. the spray wont be somethign the engine see's alot only a couple times a month.if that. im just trying to get the old motor out today it has a nice hole in the block
maybe someone can help answer this
when i heard the engine rip it self a new a-hole.the speed o and rpms everythign froze , they didnt reset just froze. and the fuel pump didnt shut off. it stayed on even with the key out. i had to unplug the magnavolt to shut it down. any ideas?
Old Jan 12, 2007 | 04:25 PM
  #85
It probably just needs to be reset by disconnecting the battery.
Old Jan 12, 2007 | 04:54 PM
  #86
2004SSS's Avatar
i did that but it remonaed on ( the guages went back to normal but the fuel pump stayed on.
Old Feb 10, 2007 | 04:16 PM
  #87
1SlowHoe's Avatar
Destroyer of Transmissions
Bringing up an oldie....
I was wondering what you guys think of the newer LS2/LQ9 rods?
Think they would hold a 370ci @ 12psi?
Old Feb 10, 2007 | 07:08 PM
  #88
Stoichiometric's Avatar
I have talked with some people who believe they will hold up well. The bolts are still the weak link, if stronger bolts are used it would be best to plastigage the bearings to make sure they stay within tolerance. The LS2 rods may limit the RPM more than the peak torque.
Old Feb 10, 2007 | 07:13 PM
  #89
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
TurboGibbs put 15#s to them with ARP rod bolts. They are nice beefy rods.
Old Feb 10, 2007 | 07:19 PM
  #90
1SlowHoe's Avatar
ARP rod bolts would be used.
The setup I'm going with will be very similar to Turbo Gibbs. Minus the copper head gaskets.
