228r in a 408?
Old Jul 20, 2014 | 03:11 PM
6.0l RST's Avatar
Default 228r in a 408?
buddy spun a bearing in his 6.0 now wants to go 408. he has a 228r 110lsa and a set of ported 243's.
i know it would choke out the 408 a little bit. but would it work and put down decent numbers?
Old Jul 20, 2014 | 03:31 PM
03sierraslt's Avatar
It will work, it will sign off a bit early with that LSA but should still have good power below 5700 or so.
Old Jul 20, 2014 | 03:49 PM
TXsilverado's Avatar
throw vic jr with 4150 style throttle body with that cam and it will scream to 6500 rpm. the truck manifold is better suited for a 112-114 lsa cam.
Old Jul 20, 2014 | 07:42 PM
gamble686's Avatar
It will depend on compression and other factors, however, it should be fine although a little bit small. Keep in mind the LS7 which is a 427 comes with a much smaller cam albeit better heads and does just fine from the factory. 211/230 .560/.557 LSA120+4 of course that is a very different cam with a very different purpose. Don't expect to push the 228 above 6200 rpm.
Old Jul 21, 2014 | 08:26 AM
Blackpanther99's Avatar
What intake mani is he going with?
Old Jul 21, 2014 | 09:49 AM
Vortec350ss's Avatar
Youre advance is wrong there... its not a plus 4.
The LSA of the smaller cam also pushes the intake close to be very late, which helps with high RPM power. Despite its much smaller numbers, ther LS7 cam keeps valves open later than that 228 does. It also opens the exhaust a ton sooner than the 228 does.
Old Jul 21, 2014 | 02:33 PM
6.0l RST's Avatar
For now he has a stock truck but I'm gunna try and swing him to a ls6 at the least
Old Jul 22, 2014 | 08:50 AM
MPFD's Avatar
11 Second Truck Club
I'm running the TBSS intake and a 236/244, no idea on horsepower...
But it does ok
Old Jul 22, 2014 | 09:37 AM
stock truck intake is just as good as a ls6 IMO
Old Jul 22, 2014 | 09:39 AM
00ChevyScott's Avatar
Wearin' da big hat
The LS6 intake sure does look sweet though
