216/220 vs 228/230 vs 227/231 cam?
Old Jul 16, 2014 | 12:40 AM
Hubcap's Avatar
Default 216/220 vs 228/230 vs 227/231 cam?
I have a 5.3 with a set of ported heads and on the flow bench my heads flowed 305/220. I had a 216/220-560/560 114 lsa tfs cam. My buddy talked to the head porter that did my heads he told him that a lunati 227/231-612/617 cam would be the best for that set up. Ok I think my 216/220-560/560 cam is to small for my heads they have 2.02/1.60 valves and I was thinking about doing a cam swap and have Ben looking at a tfs 228/230-585/585 112 lsa. With those two cams being so close to the same I think it would come down to cost. Don't want to over cam my 5.3 but don't want to under cam it either.
Old Jul 16, 2014 | 12:50 AM
gamble686's Avatar
So some important factors are unrelated to the motor or heads.
What gears, tire size, stall speed, vehicle weight, purpose and use of vehicle.
With a 5.3 no matter the setup with a 227+ duration cam I would recommend at least a 3400 stall. I personally would go a little small duration wise. 224/228 .581/.581 LSA 112 is a proven track winner. It works great for stout 5.3 builds while staying street friendly. The TFS 216/220 is much more mild.
goinbrokez28's Avatar
What stall/gears do you have, or plan to run after the swap?
Old Jul 16, 2014 | 01:07 AM
Hubcap's Avatar
Stock 3.42 for now. But I have a FTI 3200 stall. The truck is kinda a daily but more for fun. Tires I have on right now are 265/65/18. I think they are around 31 inches tall. But soon will get new tires.
Old Jul 16, 2014 | 01:08 AM
Hubcap's Avatar
Hopefully to have a 4.10 or 3.90. Somewhere n there. Tru-trac caltracks,adjustable Calvert racing shocks.
Old Jul 22, 2014 | 08:58 AM
MPFD's Avatar
11 Second Truck Club
I'd get more converter...
Old Jul 22, 2014 | 09:12 AM
00ChevyScott's Avatar
Wearin' da big hat
The 216/220 would be ok with a smaller converter and 3.42s, but changing to 4.10s would help a lot. My truck with a 228/228 112 and stock converter with 4.11s is a little weak down low but pulls hard up top. With the 3800 converter I used to have, it hauled ***.
http://youtu.be/86su-9AuG1I
Old Jul 22, 2014 | 12:13 PM
Hubcap's Avatar
Well the 216/220 cam is ok but I feel there is alot more get with a bigger cam. A 3200 is ok but I feel I should have whent 3600 or 3800 stall. For now im going to rock whatt I got. When it is time to get a new cam I want it to keep the torque but get more hp up top. 224/228 might be what im looking for. I might call up for a good custom grind cam.
Old Jul 22, 2014 | 01:10 PM
TXsilverado's Avatar
i would keep your cam until you get a 4.10 gear and some kind of posi. a 227+duration cam with a 31" tire and 3.42 gear would be pretty soggy down low.
Old Oct 10, 2015 | 06:55 PM
01silv's Avatar
How in the hell do I up load a video?
I've got that 216/220 trick flow in my lq9 ......I've had it at the strip and I'm always on the street... 148top speed and @15.01 in the 1/4
Not a hemi has beat me yet, car or truck.
