2006 5.3 lm7
Old May 29, 2007 | 04:50 PM
Biggsw784's Avatar
Default 2006 5.3 lm7
I have a 2006 CRew cab half ton with the 5.3. I am wanting to install a 2002+ ls6 cam in it and replace the springs with the comp cam 918's. curious if anyone has done this or ever seen the dyno #'s of this. I was told it would add up to 40+ rwhp.??? Not sure if i believe it or not, so thats why i am asking you guys. thanks for any help. casey
here the specs from my stock cam to the 2002+ ls6:
stock 5.3 lm7 cam
5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
2002+ ls6 cam
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
Old May 29, 2007 | 05:31 PM
silent1's Avatar
I posted a few links here regarding the LS6 cam. Scroll down and check them out:
https://www.performancetrucks.net/fo...d.php?t=392820
Any reason why you don't want to go with a slightly bigger/different cam?
Old May 29, 2007 | 08:44 PM
Biggsw784's Avatar
it is daily driven and i dont want anything that i would have to change the converter or anything like that.
Old May 31, 2007 | 03:47 PM
z71gmc06's Avatar
I have the same truck and am looking for good reliable mods to do to mine also. I am in the process of searching the forums, but would like to know what results others have gotten from their 5.3's. What rear end do you have in your truck?
Old May 31, 2007 | 08:26 PM
Biggsw784's Avatar
it has the 3.73 gear in it
Old May 31, 2007 | 08:30 PM
bluecajun5.3's Avatar
11 Second Truck Club
look into an 01 z06 cam. it will better suit your needs.
mikeyjm1
17
Oct 29, 2015 11:04 PM
gaps
Oct 15, 2015 02:53 PM
jtphelps289
Sep 1, 2015 08:58 PM
walledition
Jul 29, 2015 08:54 PM
grantpo
Jul 15, 2015 12:21 PM
