1st LS 408 engine build
Old Jul 24, 2013 | 12:36 AM
  #21
Noah Burns's Avatar
Originally Posted by zero2sixT
Lol ok man, good luck. You seem to have it all figured out.
LOL... love the sarcasm!!
Enjoy the 4.8, it aint goin anywhere.
Old Jul 24, 2013 | 01:18 AM
  #22
Batman'sChevy4.8's Avatar
Originally Posted by 1/4milelarry
I'm a little over $5300 for my bottom end. It not just crank, rods, pistons.. It's all the little stuff that adds up quick. Like bearings, main studs, seals, gaskets, oil pump, timing set up. Rockers heads intake..... The list goes on...
I have a lq9,
Callie's compstar crank- $833
Callie's h-beam 6.125 rods- $597
Wiesco -8cc dome pistons- $860
Arp main stud kit- $241
That's just parts not including bearings or labor or machine work done.
The. A good set of heads will run you at least $2000-$2500, a good intake $500-$1000. I'm gonna have around 8-9000$ into my 408. Before I upgrade fuel, trans work, or have any of it tuned...
- Lunati Forged Crankshaft
- Lunati 6.125" H-Beam with ARP 2000 Rod Bolts
- Wiseco 4.03" -3.0cc Flat-Top (10-K464X3)
- Do Not Include
- Do Not Balance
- 24x
- Standard
1975.00
King Main & Rod Bearing Set 180.00 more
Gaskets and seals I can get from work ( I work advanced auto parts)
$95 for the boring of the block
What am I forgetting?
Old Jul 24, 2013 | 01:21 AM
  #23
Have had my fun with it trying to move on to a bigger things. No sarcasm needed I just wanted a little input.
Old Jul 24, 2013 | 10:39 AM
  #24
MPFD's Avatar
11 Second Truck Club
Define not ready? Just asking, cause you will have a ton more labor and money in a 408 then you would buying a decent turbo kit for your current engine.
Old Jul 25, 2013 | 11:52 AM
  #25
Less of a question of being ready, more I don't want to put a turbo on this motor and run the risk of blowing it, 2 to 3 grand blow with it vs 2 to 3 getting a 408 started and having a 4.8 for back up should anything happen. Basically I don't want anything more to do with putting money in this little motor not saying I can't make power with it because theres a guy with a red GMC 4.8 making 900 to the wheels on youtube claims its the fastest 4.8 in the country.
Old Jul 25, 2013 | 12:45 PM
  #26
53bowtie's Avatar
The guy you are referencing with the red 4.8 is a member on here (foose04). You may want to PM him and see what he has to say about keeping your 4.8 and boosting it. He didnt blow his until over 900RWHP so if your only shooting for 450-500 then your 4.8 can live in that range with boost all day long with the proper tune and supporting mods. Plus you will get better gas mileage and better drivablity out of a boosted 4.8 over a 408. We are not trying to bash your original plan we are simply trying to let you know an alternative that would most likely cost less and be just as reliable if not more.
To answer your question on heads for the 408......stay away from your 4.8 heads or 317 heads, use L92 or Ls3 if you want to stay with a factory casting or you can check out some aftermarket castings as well.
Old Jul 25, 2013 | 01:12 PM
  #27
Atomic's Avatar
I have a gauge for that
Oh, this guy? https://www.performancetrucks.net/fo...021psi-519861/
Old Jul 25, 2013 | 02:39 PM
  #28
tim wellington's Avatar
Default heads
What if I milled the heads on my 4.8, I've read the 4.8 heads rasie the compression on 6.0s dramaticaly. Would that be better or should I sell both and go for the LS3 or L92 heads?
valves to small in 4.8 heads .for 6.0 engines .408 n.a going with L92
Old Jul 25, 2013 | 11:54 PM
  #29
Noah Burns's Avatar
for the record... in my personal truck I'd take a small cube (as in 6.0) turbo motor over a stock headed n/a 408 ANY day of the week...
Old Jul 26, 2013 | 01:55 AM
  #30
oakley6575's Avatar
I ran a very simple 408 in my DD for the past three years. Stock LS3 heads and intake with a 231/239 114+2 cam. That set up would easily meet your goals. But don't let the simplicity fool you. It will cost you the same, if not more, to build the 408 over a boosted 4.8L. And you will make a lot less power with the 408. At least if you blow the 4.8L, you can go buy another one for less than 500$. If you hurt the 408, it is most likely going to end up costing a lot of money to fix.
I just took the 408 out of my truck a few weeks ago because I spun a couple rod bearings. I went to the junkyard, bought a 4.8L and will be putting a turbo kit on it. I'm pretty much going the opposite way you want to go but I will be making a lot more power than you for less money... Food for thought
Check out my build thread in the project section. That might be a good read for you
