1st LS 408 engine build
#22
I'm a little over $5300 for my bottom end. It not just crank, rods, pistons.. It's all the little stuff that adds up quick. Like bearings, main studs, seals, gaskets, oil pump, timing set up. Rockers heads intake..... The list goes on...
I have a lq9,
Callie's compstar crank- $833
Callie's h-beam 6.125 rods- $597
Wiesco -8cc dome pistons- $860
Arp main stud kit- $241
That's just parts not including bearings or labor or machine work done.
The. A good set of heads will run you at least $2000-$2500, a good intake $500-$1000. I'm gonna have around 8-9000$ into my 408. Before I upgrade fuel, trans work, or have any of it tuned...
I have a lq9,
- Lunati 6.125" H-Beam with ARP 2000 Rod Bolts
- Wiseco 4.03" -3.0cc Flat-Top (10-K464X3)
- Do Not Include
- Do Not Balance
- 24x
- Standard
1975.00
King Main & Rod Bearing Set 180.00 more
Gaskets and seals I can get from work ( I work advanced auto parts)
$95 for the boring of the block
What am I forgetting?
#23
#25
Less of a question of being ready, more I don't want to put a turbo on this motor and run the risk of blowing it, 2 to 3 grand blow with it vs 2 to 3 getting a 408 started and having a 4.8 for back up should anything happen. Basically I don't want anything more to do with putting money in this little motor not saying I can't make power with it because theres a guy with a red GMC 4.8 making 900 to the wheels on youtube claims its the fastest 4.8 in the country.
#26
To answer your question on heads for the 408......stay away from your 4.8 heads or 317 heads, use L92 or Ls3 if you want to stay with a factory casting or you can check out some aftermarket castings as well.
#27
#30
I ran a very simple 408 in my DD for the past three years. Stock LS3 heads and intake with a 231/239 114+2 cam. That set up would easily meet your goals. But don't let the simplicity fool you. It will cost you the same, if not more, to build the 408 over a boosted 4.8L. And you will make a lot less power with the 408. At least if you blow the 4.8L, you can go buy another one for less than 500$. If you hurt the 408, it is most likely going to end up costing a lot of money to fix.
I just took the 408 out of my truck a few weeks ago because I spun a couple rod bearings. I went to the junkyard, bought a 4.8L and will be putting a turbo kit on it. I'm pretty much going the opposite way you want to go but I will be making a lot more power than you for less money... Food for thought
Check out my build thread in the project section. That might be a good read for you
