09 5.3l cam swap, afm & vvt delete
Old Apr 29, 2016 | 10:20 PM
  #21
Taylor Bickett's Avatar
So I have found the time and space for my swap. Only problem is it's 150 miles away... And I won't be able to have a tune for it on the way back. What do you think? Should I do it over the weekend or have a shop do it? I used to work at the performance shop I'm bringing it to so I trust them AND I will have a tune right away it's just I wouldn't mind doing it on my own.
Old Apr 30, 2016 | 08:22 AM
  #22
Wolftrk99's Avatar
What cam are you running??
Old Apr 30, 2016 | 11:12 AM
  #23
TSP 220r .600/.600 112lsa
Old Apr 30, 2016 | 11:25 AM
  #24
FFDP's Avatar
It's going to need a tune before you even start it up after the cam swap.
The DoD feature needs to be turned off for sure.
Old Apr 30, 2016 | 11:35 AM
  #25
I do have my diablo intune tuner so I can shut it off with that. But I wouldn't even be able to start it? Dod doesn't come on until a certain time.
Old Apr 30, 2016 | 12:35 PM
  #26
Wolftrk99's Avatar
Somehow i just dont pucture that running without a tune, at least not for 150miles.... Would you be able to bring them the pcm to get a base tune done??
Old Apr 30, 2016 | 12:39 PM
  #27
Wolftrk99's Avatar
With the diable you may be able to get a tune, to get you to the in person tune
Old Apr 30, 2016 | 12:40 PM
  #28
Damn, oh well I will just have them do it.. Their tuner is in Watertown SD which is 350 miles away so the ecm has to be sent out. He usually gets it back within a day though. Maybe I will do the headers myself so I can say I took part in it lol
It sucks I have to wait til the 25th now
Old Apr 30, 2016 | 12:47 PM
  #29
Wolftrk99's Avatar
Ifbthey have to send the pcm out anyway, take the pcm and have them get a base tune on it, as i said you may be able to get a base tune with the diablo to get you where you need to go.... Be ahell of a lot less expensive then paying someone else to do it!!
Old Apr 30, 2016 | 02:13 PM
  #30
So basically what your saying is send my ecm now and have him do the bare minimum to get it to run decent with a cam. Drive my stock pickup with that tune to where im doing this, swap cams, etc.. Then do a more fine tune after I have driven back to Bismarck? Just making sure I understand you!
