08 Sierra Cam Question
Old Oct 8, 2008 | 03:55 PM
rockerjoe2008's Avatar
Default 08 Sierra Cam Question
Just got off the phone with comp cams. I called them to get their opinion on a cam upgrade for my truck. I was told that they currently don't have any cams available for my truck because "the newer late model engines use a different core." I am new to cams and don't really understand a lot about them. But my question is do any of you know of a cam combo that work in my truck. The engine is a 5.3 flex fuel with displacement on demand. The engine is stock expect for a p1sc procharger running 8-9lbs, 42lb injectors and a boost a pump. Sorry if this is a newbie question but I was under the impression that there were cams available for my truck.
Old Oct 8, 2008 | 04:22 PM
sickREDsierra's Avatar
they are. i would choose a grind close to a gt2-3 cam for the charger. let me see if i can find you some reading material...
Old Oct 8, 2008 | 04:23 PM
https://www.performancetrucks.net/fo...play.php?f=188
copy/paste your question here... lots of good info for the NNBS trucks.
Old Oct 8, 2008 | 11:16 PM
thanks, I'll check it out. BTW what does NNBS mean, it wasn't on the acronym thread?
Old Oct 9, 2008 | 08:33 AM
circusboy's Avatar
New New Body Style.
The old motors, lol, used a 3 bolt cam gear setup. ie 3 bolts to attach the gear to the cam. The new motors use a 1 bolt cam gear. ie 1 bolt to attach the gear to the cam.
Do you have a VVT motor (Variable Valve Timing)? I think that's a different animal as well. I'm sure someone will correct me if i'm wrong
Old Oct 9, 2008 | 08:37 AM
circusboy's Avatar
I forgot to mention. I have AFM, but not VVT. My first cam was a regrind on a stock core. It was a single bolt cam. My new cam is a 3 bolt cam. You can use the 3rd gen cams with a Z06 cam sprocket and they will work. I have the part numbers at home or you can just do a search on here.
Old Oct 9, 2008 | 04:47 PM
Not sure if mine is a VVT, how can I find out? Feel like it probably is.
Old Oct 9, 2008 | 05:25 PM
norris_83's Avatar
from wat i know of, all 5.3s come without VVT.. its the 6.0s and 6.2s that use the VVT..
ive upgraded my cam to a xr265hr comp cams...just changed out the cam gear for a gen3 and i was off....no dtcs, nothing
Old Oct 9, 2008 | 09:30 PM
scooter k's Avatar
5.3 doesn't have VVT
Old Oct 9, 2008 | 09:40 PM
Ok good to know. Sounds like the guys at comp cams was full of it. Shouldn't be that hard to find a replacement cam then, right?
