02' Silverado Piston Knock???
Old Nov 7, 2006 | 04:34 PM
Tileking13's Avatar
Default 02' Silverado Piston Knock???
I have a 2002 silverado with a 5.3, and i have the piston knock that many people have said are prevalant in these motors. Has anybody found a why to fix this with out havin to replace the piston rings?? Or at least a way to help reduce as much knock?? Any info is really appreciated!!
Old Dec 2, 2006 | 01:23 AM
craze4speed's Avatar
if you are talking about the knock that you hear on a cold start there is a temporary fix that will last for a while and that is to pull the spark plugs out and go to a gm dealership and get two cans of top engine cleaner spray or pour which ever you can get in the cylinders the best and fill each cylinder with it and let it sit over night and the next day spin the engine over with the plugs out and the ignition disabled until all the fluid is out and then put the plugs back in and it will fix youre problem. i work at a gm dealership and that is what we have been doing to fix that problem
Old Dec 6, 2006 | 06:46 PM
Jipper's Avatar
That is one way, but way too time consuming, no need to pull the plugs at all.
Go buy a can of sea foam, and slowly pour it down your brake booster line (attached to master cylinder) Your engine will bog down and die, let it sit for a while, start your truck and enjoy the smoke show.
This is one of the best ways to clean up the deposits in the engine
ferrellrooster
Mar 6, 2025 03:22 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
greedygenius
Sep 3, 2015 06:51 AM
lycominghunter
Aug 15, 2015 12:26 PM
04450r
Jul 30, 2015 02:04 PM
