02 5.3 flywheel on 03 6.0 Lq4?
Old Jul 31, 2006 | 11:57 PM
Tahoe6.0's Avatar
Default 02 5.3 flywheel on 03 6.0 Lq4?
Can I use my 2002 Tahoe 5.3 flywheel on my 2003 LQ4 engine on the swap? Is it the correct one or will i have to drill new holes? Any Spacer issues? How About vibration problems.
Old Aug 1, 2006 | 07:33 AM
TurboGibbs's Avatar
on that late of a model you shouldn't have any issues. on the first year or two of 6.0's there was a longer crank or spacer used. The gen 3 engines are all internally balanced so you should be able to use the 5.3 flexplate on the 6.0.
Old Aug 1, 2006 | 07:35 AM
pretty much everything else on these engines fit and are interchangeable so the flywheel should be the same way.
Old Aug 1, 2006 | 10:34 AM
Colby 04's Avatar
why wouldn't it work???
Old Aug 1, 2006 | 10:48 AM
Last Call's Avatar
TOTM: January 2007
Is it getting bolted up to an 80e or 60/65e?
thunder550's Avatar
High on diesel fumes
It will be fine. The only way you would run into spacing or hole alignment problems is if you were swapping to a 4L80E also.
Old Aug 1, 2006 | 01:50 PM
Quik's Avatar
5 year bitches!
i would use the 5.3 FLEXPLATE and not he lq4 one unless using a 80e
Old Aug 1, 2006 | 07:50 PM
litreddevil's Avatar
Banned
why i have a 6.0 fly wheel and a 5.3 fly wheel on top and side by side and they are the same
Old Aug 1, 2006 | 10:44 PM
Tahoe6.0's Avatar
Thanks for the help!
GrooveCityZ71
Aug 31, 2015 12:05 PM
Abuckeye
Aug 19, 2015 06:11 PM
slowlsx
Aug 10, 2015 05:33 PM
bsn1989
Jul 16, 2015 08:20 AM
davis28905
Jul 8, 2015 03:20 AM
