When I think DI... I think of this
Old Jan 9, 2018 | 12:46 PM
  #51
Mark Johnson's Avatar
Found something called B 12 chemtool. looks promising.............
Old Jan 10, 2018 | 12:42 PM
  #52
BudRacing's Avatar
Best cleaner I've used.
Old Jan 11, 2018 | 06:59 AM
  #53
gagliano7's Avatar
I used the B 12 chemtool to clean the top of my pistons when i took my engine apart. Put on the pistons waited 10 minutes and the carbon wiped right off. Everything else i tried carb cleaner, wd40, seafoam and others nothing worked like the B12.
Old Jan 15, 2018 | 11:40 AM
  #54
colekill's Avatar
KickinAssAndTakinNames
20k miles I’m at the delership right now for my last free oil change. They recommended a throttle body cleaning service for 140 bucks. She said they use BG something.....
Old Jan 16, 2018 | 06:10 AM
  #55
Zman82's Avatar
Looks like it goes in the gas tank
Any cleaner that goes in the gas tank does not work for DI
The entire reason DI has a cleaning issue is because the injectors are sprayed directly into the combustion chamber, thus the fuel is not sprayed into the head and valves anymore, which acts as sort of a self clean.
Old Jan 16, 2018 | 11:32 AM
  #56
BudRacing's Avatar
B12 also comes in aerosol cans. I've used it to clean up the pistons when I pulled heads. It worked better than any other cleaner I had on hand. If it's not available in aerosol, I'd put it through a pump sprayer just the same as the BG video did.
