Any noticeable gains in MPG from anything you've tried? Headers?
Old 02-07-2018, 05:44 PM
  #61
FFDP's Avatar
You will want to verify if your have a real sensor or a virtual sensor through. Even though it's a E85 or flex fuel truck does not always mean it has a real sensor that is accurate.
The older GMT-900's that are flex fuel trucks all run what they call virtual sensors that use the fuel trims to determine alcohol content. It's not a very accurate way to read it and it is very slow to react to the changes unlike a real sensor that could figure it out in just a few minutes.
I always hear of people having issues when they try to blend fuels or run one tank of E85 then switch back to 93 octane, the virtual sensors will take forever to adjust the calibration back.
Old 02-07-2018, 08:42 PM
  #62
Gorske's Avatar
Originally Posted by 00pooterSS
Ah now I see. Cool I have a e85 compatible truck so I won't have to do anything but the tuning part
When you ran the 13.9, did it have the stall? Just cold air and the muffler and piping and e85?
13.96 pass was a K&N drop in filter, muffler swap, and e85 tune.
Old 02-08-2018, 12:24 PM
  #63
1994Vmax's Avatar
2014+ trucks run a real alcohol sensor in the fuel line. Even the 2500HD's do as they have been that virtual trash in the past like the 1/2 ton GMT900's.
Old 02-08-2018, 04:25 PM
  #64
FFDP's Avatar
The 2500's must be after 2015 as the 2015 file I have still says virtual sensor from the factory.
Old 02-08-2018, 06:49 PM
  #65
1994Vmax's Avatar
Its funny because HP or whatever is wrong there... says that same virtual or whatever BS on my 17 HD too. But yep.. crawl under the truck and there sure is an alcohol sensor in there just like the 1500 series trucks. Although all the gas HD trucks have a sensor you can still get a half ton without e85 capability and I could see those being virtual and it's probably a labelling thing on the interfaces end at that point.
Old 02-08-2018, 06:52 PM
  #66
FFDP's Avatar
Silly hpt.
Old 02-08-2018, 06:58 PM
  #67
1994Vmax's Avatar
Plus the HD has a stupid ECM that is shared with cool cars like Cruzes... and has minimal support. The E78 is kind of worthless.
Old 02-08-2018, 07:02 PM
  #68
FFDP's Avatar
Yeah it baffles me why they used that controller. The E38 was just fine for everything else up to 2013 in the half ton market and then like 2012 hits they decide to screw with things for the heavy duty line.
Old 02-08-2018, 07:07 PM
  #69
1994Vmax's Avatar
Yup. We shall see if I even can get e fans working properly on it or not. The Suburban HD has them but that doesn't mean much lol.
Old 02-09-2018, 11:37 AM
  #70
00pooterSS's Avatar
Damn that's it.. badass
Thanks for the heads up and the info
I knew something was funny with the older flex fuel gm's. I've had a couple come in the shop with rich codes and found nothing wrong, except that they were in fact running rich. I reset the fuel adaptive tables and the problem goes away. I realized since it went away after resetting the adaptive tables that it was fueling for fuel that had high alcohol content, but didn't have fuel in the tank that had high alcohol content, so they were dumping extra fuel and they had a rich mixture due to that.
Justinrst
01-11-2011 02:35 PM
xsports33
02-07-2010 07:13 AM
chacho44
22
11-04-2009 02:23 PM
treyZ28
05-03-2006 07:40 AM
marc_w
07-28-2004 10:31 PM
Quick Reply: Any noticeable gains in MPG from anything you've tried? Headers?
