2017 5.3 ProCharger times
Well I finally made it to the track. I only got two passes before it started raining again...
Little back story first......
Truck stock ran 15.21 @ 89.86(1/4) 9.70 @ 70.46(1/8) with a 2.13 60ft. with 93 4wd launch stalled up to 2500rpm and switched to 2wd after that launch.
Best 93 time with a tune, K&N drop in filter, Airaid MIT, and custom cat-back was 14.40 @ 94.78(1/4) 9.22 @ 75.31(1/8) with a 2.07 60ft. same type of run stalled up 2500rpm, 4wd launch, and switched out to 2wd after the launch with 6100rpm shift points.
Now to todays runs. First pass I screwed up and over powered the brakes and broke the beams but it gave me an idea what my mph would be 82.06mph in the 1/8 and 103.12mph in the 1/4 with launching it in 4wd stalled to 3200 rpm with it flashing to 3800 rpm and leaving it in 4wd the whole pass spun all 4 tires on the launch.
Second pass and last pass due to weather was 13.22 @ 102.44(1/4) 8.42 @ 81.37(1/8) with a 1.87 60ft. That was launching it in 4wd stalled to 2500rpm flashing to 3800rpm and leaving it in 4wd for the whole pass 6200 rpm shift points and truck spun all 4 again but there were sprinkles between rounds and they did not dry and respray the track. Mods for that pass ProCharger P1(10psi at peak rpm), Circle D 278mm single disc 3200 stall, Klug Performance 93 tune, Black Widow 250 custom cat-back, stock manifolds and stock cats. It was 64 degrees with a DA of 1034 so not horrible air quality.
Now why did I post my 93 times because my one 13.96 pass and consistent 14.10 passes were on e85 and being I am running 93 with the ProCharger I wanted to try and compare apples to apples. Another difference with todays times were I left it in 4wd just to be careful and keep traction. Now in the past I showed leaving it in 4wd versus switching out of 4wd after the launch was good for 1-2 tenths in the 1/4 before on my truck. I am going to Milan Dragway on Wednesday and I will test that out there to see the time difference. I honestly think with better traction, and switching out of 4wd I will see 12s with my current setup. As always the tune is far from done and will keep you posted on all my progress. I am very happy with the truck and think my times today were a very good start.
Like always please let me know what your thoughts are on how the truck is running.
Yeah you were traction limited but at least its a start and not bad at all. You definitely have 12's imo. Nice!
I have a gauge for that
Nice! Pay more attention to the MPH than the ET when you are getting it dialed in. It is much easier to be consistent power wise with MPH than ET since it does not depend so much on the launch and such. Max out your MPH then work on suspension and launching to get the ET lower.
someotherguy
05-15-2020 12:12 PM
Gorske
43
05-29-2018 12:48 PM
