valve train noise?
Old Jan 15, 2013 | 08:38 PM
  #71
AUTOT3K's Avatar
I held it at 3500 for like 20 seconds before going on my road test. According to oil sensor data its at 176kpa at idle
Old Jan 15, 2013 | 08:42 PM
  #72
2000chevysilverado's Avatar
How about in standard should be 60 psi
Old Jan 15, 2013 | 08:45 PM
  #73
AUTOT3K's Avatar
Its at 26PSI at idle
Old Jan 15, 2013 | 08:47 PM
  #74
Thats low hook up a gauge first did you change anything on the pump
Old Jan 15, 2013 | 08:50 PM
  #75
AUTOT3K's Avatar
No I left the pump alone. Replaced the o ring. And made sure not to pinch it oanything
Old Jan 15, 2013 | 08:53 PM
  #76
1994Vmax's Avatar
Idle isn't that bad at 25 pounds but watching your guage while you are on the throttle troubles me more. Do you ever even surpass 275 kpa? ( 40 psig for you guys that can't operate an online convertor). Was your oil pressure always like that even before you did the cam? Just seems low to what I am used to. Maybe you have a lifter or two or three that are on their way out..... Assuming you of course used the ever so wonderful LS7 lifters.
Old Jan 15, 2013 | 08:56 PM
  #77
AUTOT3K's Avatar
It does get to about 275kpa which is lower then before...like ever since the noise crap started the oil pressure has beeb a hint lower. Its better now without the fram oil filter but still not great.
Shop key claims 6psi at idle is acceptable and 24psi at 4000rpm
I did use the ls7 lifters
  #78
SlickSierra's Avatar
What color o-ring did you use?
Old Jan 15, 2013 | 08:59 PM
  #79
AUTOT3K's Avatar
I can't remember the colour. Its whay sdpc sent me.
Part number I think 12557752 just looking at my invoice. It wss yhe only "seal" at $6 so must of beeb the o ring
Old Jan 15, 2013 | 09:02 PM
  #80
AUTOT3K's Avatar
Google search on my phone brings that pn as a blue o ring
