U Bolts?
Old Apr 20, 2011 | 09:39 PM
camaross82's Avatar
Default U Bolts?
Hey I was gonna remove the lift block on my truck and was wondering where you guys are getting the u bolts from? Ive tried napa and advanced and neither of them had the right size.
Old Apr 20, 2011 | 10:45 PM
FrankyRST's Avatar
you dont need new ones, the stock ones have should enough thread
Old Apr 20, 2011 | 11:39 PM
cdub81's Avatar
http://www.gmpartsdirect.com/
Old Apr 20, 2011 | 11:44 PM
silverado1ss89's Avatar
If I remember correctly ... I use two bolts.. I put on in.. The second one I tighten.. It worked good.. Keep my stock u bolts..
Old Apr 21, 2011 | 08:04 PM
Murphdog's Avatar
I got mine from thesuspensionking.com. Square bend, 9/16" dia, 2 1/2" inside width, 7" long. You can reuse the stock bolts, but they'll hang down an extra 1 1/4" and be quite noticable. Most of the places that sell u bolts recommend that you don't reuse them, though, due to the rolled threads.
Old Apr 23, 2011 | 12:29 AM
I had 24's when I took off the lift blocks and shackles.. And you couldn't see it .. Unless you go under the truck
Old Apr 23, 2011 | 01:47 AM
two-piece's Avatar
You can easily reuse them, if they hang low get out the grinder with cut off wheel.
Old Apr 23, 2011 | 10:18 AM
Beatdown Z's Avatar
Laid Back
Same here. Bought from them multiple times.
natejk
Nov 15, 2016 08:05 AM
Justin87gn
Sep 10, 2015 12:06 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
