tow haul mode NNBS 4l80e swap
Hi all:
swapped a 4l80e into a GMT900 in place of a 6l80e, using a PCM of NC conversion harness, and a T42 GM controller. Runs and drives great.
I am trying to get tow haul mode to work for an alternate shift pattern. I first tried modifying pattern A and B with no success (raise 3-4 shift MPH to 200 to prevent shifting to OD). The light on the dash comes on with the push of the button, but the TCM wont respond to the commanded change. I know not a ton of people have done the 6l to 4l swap on the GMT900's, but I thought I would throw this out there.
Any thoughts?
Do the GMT900's use a canbus data line to switch the modes?
Any thoughts?
Yeah we did get it to work, and without an OS swap as well. Alvin just had to change a whole bunch of settings around, and it works great, pattern a is normal shift, pattern b is tow haul.
dang, 5 years later! Sold the truck ages ago and I don't remember what he changed to get it to work, but I can do you one better. I happened to save the tune, so if you have HP Tuners go ahead and take a look at the file and see if you can compare what is different. good luck!
-LT
-LT
TwistedBigRig
Apr 3, 2016 04:55 PM
Alvin@PCMofNC
Mar 25, 2016 11:16 AM
rednekferlife101
20
Mar 21, 2016 12:03 AM
