Tire size for 5" lift
makes children cry
@arthursc2 Says no they cannot.
285/75-16s absolutely rubbed on my Tahoe. Even even I used "lift" keys and had 0" of droop travel. Rode like ***, still rubbed- esp full lock in reverse
But pavement princesses are definitely treated different than my Tahoe is, and I know for a fact I drive that truck off-road more than anyone here does, so your results may vary
If you're willing to cut, you can fit anything. 52s at stock ride height is just a grinder away from working lol
Use a calculator to calculate the new rear axle gear ratio. There's a few out here. Here's one: https://www.randysworldwide.com/calc...sion-ratio-rpm
Ideally you want to cruise close to where your engine is operating close to the top end of the powerband. That will enable to give your truck throttle and it will accelerate without downshifting or bogging down (engine lugging, which considered a bad thing for durability.)
2200-2500 rpm cruising I find is pretty good on these engines (I have a 5.3 and 6.0)
thought along the torque plateau was the operating range, I don’t want my engine at max hp peak for anything but WOFun
strutaeng (04-24-2024)
4.8chevysilverado07
11-13-2011 05:43 PM
