tc/stabilitrak annoyances
Old Feb 8, 2011 | 03:37 PM
  #31
You cannot use the stock switch to activate the relay. I used a hidden rocker switch.
Old Feb 8, 2011 | 03:49 PM
  #32
skoal bandit's Avatar
I don't have that problem at all. As long as I see traction and stabilitrac off, i can step the back out on the street without stabilitrac kicking in. I did hear that it acts up on the dyno though and with smaller drag radials on the back too. I pulled the fuse when i had the DRs on cause someone told me too. Not sure what would have happened if i wouldn't have pulled the fuse.
Niff, did you pull your fuse when you had the DRs on it or Sheltons tune solved that problem?
Old Feb 8, 2011 | 09:56 PM
  #33
fredkj3's Avatar
maybe its only on the 6spds... seems like you 4l60e guys arent having the same issues
Old Feb 9, 2011 | 11:10 AM
  #34
carbongmc's Avatar
^^^ that was the same thing i was thinking....
Old Feb 9, 2011 | 11:58 AM
  #35
Rhino79's Avatar
9 Second Club
I had the issue, posted in here, on the efilive forum, had my own thread here. I thought I was going crazy, but its good to see I am not the only one that had this problem. I have the 4 speed. It seems to be a minimal to mild wheel spin. Since I put the converter in, I can roast the tires, I don't think it can keep it from spinning once you get past a certain point.
Old Feb 10, 2011 | 09:06 AM
  #36
8.1 HD's Avatar
Guys running EfiLive make sure that B2523 in pcm tune is set to yes.
Old Feb 10, 2011 | 10:09 AM
  #37
Jordan927's Avatar
Yeah +2 on that.
My bud's 4.8 can get all kinds of snakey...My truck however doesn't want to kick out at all unless I really push it. Since the Diablo Update its much better...but its still not where I want it.
Old Feb 10, 2011 | 10:16 AM
  #38
carbongmc's Avatar
What exactly is this going to do in the tune? I ask because Im getting mine tuned with EFIlive this weekend.
Old Feb 10, 2011 | 10:18 AM
  #39
Rhino79's Avatar
9 Second Club
I dont have my tune on this pc but I think it disables the BTM (brake torque management). I could power brake it and spin before with the BTM set to disable, but as soon as I let off the brake, it would still kick in and apply brakes.
Old Feb 10, 2011 | 12:46 PM
  #40
8.1 HD's Avatar
It's TCS off disables BTM. On my tahoe that was the limiting factor, with the TCS on it kicks in...but not like factory as I have tuned it out some, with TCS off I can go out and play in the snow, drifting, donuts, etc.
