supporting and lifting motor for motor mounts
Old Nov 4, 2014 | 04:28 PM
40series's Avatar
Default supporting and lifting motor for motor mounts
where and how do i lift and support the motor for replacing motor mounts with out damaging oil pan
Old Nov 4, 2014 | 07:26 PM
Atomic's Avatar
I have a gauge for that
I typically put a bolt in the front of the passenger head and one in the back of the driver head and put a chain across to lift the engine. Make sure the bolts are threaded in all the way. Its also possible to lift the engine from the valley bolts, but you will need to make a plate or something.
Old Nov 4, 2014 | 07:34 PM
GMCtrk's Avatar
2x4 under the oil pan and lift with a jack. The motor only has to be lifted minimally to get the motor mounts out.
Old Nov 4, 2014 | 08:05 PM
40series's Avatar
Default no cherry picker
i dont have a chery picker
Old Nov 4, 2014 | 08:06 PM
40series's Avatar
Default will this mess up my oil pan?
will supporting the motor under the pan like you said ruin my oil pan pick up tube ? like i read ???
Old Nov 4, 2014 | 08:30 PM
Wont hurt it put 2x4 etc to spread the load evenly use a floor jack and it will be fine. The oil pan is cast aluminum you would really have to put some weight on it to hurt it.
Old Nov 4, 2014 | 08:38 PM
40series's Avatar
Default ok wood across the pan sounds do-ABLE
ok 01WS6/tamu wood 2x4 across the oil pan sounds do able as suggested by other members
Old Nov 4, 2014 | 08:39 PM
40series's Avatar
ok i will try this thanks for the tip
zblee
63
Jun 10, 2023 01:25 PM
TXsilverado
Nov 26, 2015 10:54 AM
BennyB
Aug 1, 2015 08:48 AM
jmarkway
Jul 18, 2015 09:23 PM
