service stabilitrak/service traction control, why does this keep coming on?
Old Nov 9, 2011 | 07:21 AM
bud8fan's Avatar
mine does that every time i drive it...it was so bad that it would throw me into limp mode if i got on the throttle from a stop and would not reset if i just restarted the engine...had to pull neg battery cable to reset...anyway we actually narrowed it down to ecm...changed it and the stabil trac/traction control message still comes on but it doesnt throw me into limp mode anymore...
Old Nov 9, 2011 | 12:14 PM
2007chevy5.3l's Avatar
Mine used to do it alot before I pulled the trans for the stall swap. After the swap ive only had it come on once... Guess its a bad connection somewhere?
Old Nov 10, 2011 | 05:59 AM
Ieatpeople's Avatar
did it again this morning, checked for codes while running, "no codes found". wtf?
Old Nov 11, 2011 | 09:17 AM
Lloyd-TX's Avatar
Most likely it's your steering wheel position sensor.
They're VERY problematic on the NNBS trucks. My SD needs one right now, as a matter of fact. Keeps setting a C0710 code.
Old Nov 15, 2011 | 01:13 PM
Ieatpeople's Avatar
i read that, and started laughing. then i realized you weren't kidding. there is such a thing as a "SWPS".
ZR1 forum thread about code C0710
i'll have to check the connector for corrosion, and see if it stops doing it.
Old Dec 10, 2012 | 05:32 PM
305ChevyTahoe's Avatar
Registered User
I am having the same issue with my '07 Tahoe LT 5.3L. Message Center cycles: Service Stabilitrak, Service Traction Control, then it goes to Engine Power is Reduced and rides like a farm tractor. Happened on Friday 12/7. Parked it for a few hours then drove it home about 15 miles. Drove fine today, but last night went bonkers again. I took it to the dealer today and they said I need a new throttle body. Got 98,000 miles on the clock, never had a problem before. I will change out the thottle body and an evap solenoid that's been bad for awhile and report back. They said I have 5 codes at the dealer. I changed the battery over the w/e and installed a new air filter, both of which were overdue.
Old Dec 10, 2012 | 06:29 PM
ak2007r6's Avatar
See if you can get the codes they said you had.. be curious to see what they were.
Never would have guessed the throttle body....
Old Dec 10, 2012 | 08:11 PM
Robert91RS's Avatar
Seen the TB cause it a number of times. Its a problem with the TPS in the early throttle bodies(07-08). Pt#12580760 if memory serves me but GM recently released a TPS service and replacement kit too (haven't memorized that # yet).
Old Dec 10, 2012 | 08:49 PM
Koots's Avatar
My parents 09 Sierra has been in for 2 throttle bodies now...which is ridiculous, but it's also friggin cold here and brutal on everything.
Old Dec 10, 2012 | 08:50 PM
Koots's Avatar
If it was my vehicle, I'd take the TB off and clean everything out, but these DBW throttle bodies are kinda alien to me.
