Rear suspension noise
Well before I explain my issue ill let you know a little about the truck. I own a 2011 sierra denali AWD. I bought it new in 2011 and it has 15000 miles right now. Right after I bought it I installed blistein 5100 shocks all around it. Well this week I just ordered 2" drop shackles and hellwig sway bars for front and rear. I would like to figure out my issue before I put these new parts on if possible.
So now that all the info is there this is my issue. Wednesday my wife and I were going to dinner and noticed when we pulled out of the driveway that once the rearend hit the bump that it made a clunk type noise and sounded like something was loose. I pulled out of the driveway going forward and turning left. Fast forward to today and I used a speed bump and took all four tires over the bump singaly. Now, each time I take the right rear tire over it in any way it makes that exact noise. So I took it to my garage to inspect, I really found nothing, I tightened every nut and bolt imaginable back there and my rims. Still the same issue.
Any suggestions for what to do?
No, just some straps.
Maybe ill call the dealer since its still under warranty.
But only when I hit a bump AND turn left while doing it. I've checked all bolts and they are tight too. Maybe I should try the greased up leafs...
hmmmm.... not trying to thread jack, but since I put on my new shocks and DJM flip kit, something in the rear pops or clunks as well.
Well guys, I have figured it out. I went ahead and installed my drop shackles tonight. My friend and I got them on in about an hour, then took my truck for a drive before reinstalling the hitch. I drove my usual route to work and to my surprise the truck never made the normal sound once. So, I am guessing it must have been the stock shackles, possibly the rubber bushings had an issue.
