offset for our trucks?
um.. well if u were looking for tucks and stuff u would want a +18 at least, depending on how low u were dropping it. With 33" (I take it its some what lifted or will be??) I wouldnt worry about offset at all, cuz the 10" rims usually stick out for off road fitments. For example my rears(9in) are +0 offset and stick out of the fender about a 1/4 of an inch.
Keeping in mind that offset is a function of wheel width, the answer is...it depends.
Stock offset is +31mm on an 8.5" wide wheel. You do have quite a bit of room to play with, especially since you're going up instead of down. Here's a great tool for comparison:
http://www.1010tires.com/WheelOffsetCalculator.asp
Offset is not a function of wheel width. Offset is the distance from wheel centerline the mounting face. You can have a 6" wide wheel or a 12" wide wheel and a +31 offset is still the same offset.
You are talking about backspacing. Backspacing takes offset and relates it to wheel width. Backspace is the distance from the inner edge of the wheel to the mounting face.
You're right - sorry for not clarifying. Wheel questions like this are confusing and I attempted to make this one a bit easier. In more detail, what I was trying to say is that offset alone is insufficient to determine fitment if you're comparing wheels of different widths. Since you can determine backspacing if you know the width and offset specs, I generally leave it out of the equation.
Suburban2500
Jul 19, 2015 04:50 PM
