Need some advice........
Old Feb 26, 2011 | 08:36 AM
  #51
Mark Johnson's Avatar
Thanks, rj- i'm just getting into the legal speed limit kick- downs now, a little rough up there, just like Moms' Esky was wehn newer. Gotta take out that 99mph govorner soon.........
Old Feb 26, 2011 | 10:45 AM
  #52
fredkj3's Avatar
my trucks not a NHT but it has everything you listed except for 3.73..
i have the 6.2L
i have the 9.5 rear end with G80 locker
i have 4 wheel disc brakes
i have a trans cooler
i dont know about the suspension but from what i can see the only real difference is the gear ratio
Old Feb 26, 2011 | 01:33 PM
  #53
rjwz28's Avatar
Man Motor club
i have the 6.2L
I believe you're right about the gear ratio being the only difference; however, that single difference bumps up the towing capacity by half a ton. I like it because it keeps my truck in the sweet spot despite the taller tires; I don't even notice the extra rubber when I'm driving around.
Old Feb 28, 2011 | 08:26 AM
  #54
I was wondering the samething, about coolers and all. I do like the 3.73 gears, though. It's go a little more zip than Mom's Esky with 3.42's. This truck should be in the movies...........
P.S. I've been mulling thru the RPO's and I knew the truck had Traction Contol, but it also specifies that JL4 has stabilitrak, what exactly does that include and do...........
Old Feb 28, 2011 | 08:39 PM
  #55
rjwz28's Avatar
Man Motor club
Stabilitrak is stability control, designed to keep vehicles manageable for the average idiot. I turned off the traction control today and did a burnout (in sand) with Stabilitrak still engaged; once I started to kick the tail out, the system engaged the brakes in such a way as to prevent me from getting sideways. To play, hold down the Traction Control button, which is located to the right of the cigar lighter/outlet. You will see a message on your display indicating that the Traction Control has been turned off. Keep the button depressed until the display informs you that Stabilitrak has been disengaged. Once I disbled both systems, I was able to do everything I wanted with no (noticeable) interference. I was sliding my truck all over the desert like a total hooligan; it was great However, some guys on here have been saying that they had to pull the ABS fuse to remove all TC/Stabilitrak nannies.
Old Feb 28, 2011 | 08:43 PM
  #56
rjwz28's Avatar
Man Motor club
Oh and I've been considering a full tune myself, governor removal included
Old Mar 1, 2011 | 10:35 AM
  #57
Ahhh- keep holding the button down to turn everything off. I've pressed the bottun briefly and it says traction control off. Just went out and held it for a few more seconds it then said Stabilitrak is now off, thi sis cool as hell, maybe I can do some burnouts after all now............
Old Mar 1, 2011 | 01:12 PM
  #58
rjwz28's Avatar
Man Motor club
I've got a $1200 set of rubber wrapped around my wheels, so no smoky burnouts for me I have been able to go play out in the sand though
Old Mar 2, 2011 | 11:40 AM
  #59
I think I'm gonna hafta yank a fuse, I still can't do anything with everything turned off....................
Old Mar 2, 2011 | 12:04 PM
  #60
BrutalSierra's Avatar
I have been unable myself. I tried yanking the fuses with no luck. Am i missing something?
