Need some advice........
#52
my trucks not a NHT but it has everything you listed except for 3.73..
i have the 6.2L
i have the 9.5 rear end with G80 locker
i have 4 wheel disc brakes
i have a trans cooler
i dont know about the suspension but from what i can see the only real difference is the gear ratio
i have the 6.2L
#53
i have the 6.2L
i have the 6.2L
#54
I was wondering the samething, about coolers and all. I do like the 3.73 gears, though. It's go a little more zip than Mom's Esky with 3.42's. This truck should be in the movies...........
P.S. I've been mulling thru the RPO's and I knew the truck had Traction Contol, but it also specifies that JL4 has stabilitrak, what exactly does that include and do...........
#55
Stabilitrak is stability control, designed to keep vehicles manageable for the average idiot. I turned off the traction control today and did a burnout (in sand) with Stabilitrak still engaged; once I started to kick the tail out, the system engaged the brakes in such a way as to prevent me from getting sideways. To play, hold down the Traction Control button, which is located to the right of the cigar lighter/outlet. You will see a message on your display indicating that the Traction Control has been turned off. Keep the button depressed until the display informs you that Stabilitrak has been disengaged. Once I disbled both systems, I was able to do everything I wanted with no (noticeable) interference. I was sliding my truck all over the desert like a total hooligan; it was great
However, some guys on here have been saying that they had to pull the ABS fuse to remove all TC/Stabilitrak nannies.
#56
#57
Ahhh- keep holding the button down to turn everything off. I've pressed the bottun briefly and it says traction control off. Just went out and held it for a few more seconds it then said Stabilitrak is now off, thi sis cool as hell, maybe I can do some burnouts after all now............
I have been able to go play out in the sand though
