Mcgaupheys 3/5 to a 4/7 drop
Old Jun 13, 2010 | 03:10 AM
Shane B's Avatar
Default Mcgaupheys 3/5 to a 4/7 drop
Well,I would like to go a little lower with my truck.Right now Ive got the Mcgaupheys 3/5 drop,front is 2in spindles with 1in spring.Rear is flip with the block removed.Im guessing the front would be done with a 2in spring,but Im not sure how to get the rear lower.And Im guessing Im gonna need a cnotch.What do you guys think?
Old Jun 13, 2010 | 12:32 PM
Beyond Static's Avatar
The only way to have a 5" drop in the back with a flip kit is by using the rear lift hangers. Replace those with stock hangers and you'll have a 7" drop. A c-notch isn't necessary. Most run helper bags to stiffen the rear up to keep it from bottoming out
Old Jun 13, 2010 | 01:06 PM
iamkeniff's Avatar
or just run a stiffer shock and it'll only bottom out on hard bumps or if the bed is full.
Old Jun 14, 2010 | 05:34 AM
Shane B's Avatar
Ok,thanks Static!What would I need for 6in in the rear?I think 7 might be a little low for a DD.
Old Jun 14, 2010 | 09:08 PM
flip kit with the lift hanger set at it's lowest drop setting, using factory shackles
Old Jun 15, 2010 | 06:56 PM
slammed89swb's Avatar
I say notch it. I have a 4/7 on my truck and it bottoms out all the time. Well I say all the time but more than I would like it to.
Old Aug 2, 2010 | 12:40 AM
midnight6's Avatar
looking into the McGaughys 4/7 kit myself.
how did you guys do it with the rear hangers that are not bolted on?
Old Aug 2, 2010 | 12:45 PM
Red04Silverado's Avatar
I DD on my 4/7. Not that bad.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Chewy07
Nov 14, 2015 09:46 PM
Gadgetized
Oct 22, 2015 09:06 AM
smok'nZ
Oct 6, 2015 01:14 PM
twake_410
Sep 25, 2015 10:09 PM
