Ls9 Cam results, dang.
Old Oct 17, 2011 | 09:40 PM
  #71
OrangeChevyII's Avatar
No noises
Old Oct 17, 2011 | 09:51 PM
  #72
Area47's Avatar
hmmm, good to know. i think the ls9 would be a better bang for the buck option versus the ls7. front cover, gear, plug in play. rather than changing push rods, going through checking them and setting preload. im a huge fan of simplicity
Old Oct 18, 2011 | 12:32 AM
  #73
gonzo 6.2's Avatar
What is your ETA?
Old Oct 18, 2011 | 06:51 PM
  #74
Area47's Avatar
Originally Posted by gonzo 6.0
What is your ETA?
couple weeks at a minimum. bills take priority over toys.
Old Oct 19, 2011 | 02:17 PM
  #75
TheBurlyMan's Avatar
Why would this be a better bang for the buck than the LS7 cam? I thought the LS7 cam would only require the same changes and work just fine. I ask this because based on these awesome results I was going to get the LS7 cam because the duration is a little larger and LSA angle a bit more narrow. (hopefully moving the torque band down in rpm's slightly)
Old Oct 19, 2011 | 02:30 PM
  #76
Uhhh, well I just answered my own question. The zo6 cam is $350 vs Zr1 cam $130
Old Oct 19, 2011 | 03:43 PM
  #77
GMpartsguy1's Avatar
Cam 12638427
Bolts 11588723
Sprocket 12623754
Cover 12600326
Old Oct 19, 2011 | 09:15 PM
  #78
gonzo 6.2's Avatar
Originally Posted by GMpartsguy1
Cam 12638427
Bolts 11588723
Sprocket 12623754
Cover 12600326
THANKS AMIGO
Old Oct 19, 2011 | 09:19 PM
  #79
gonzo 6.2's Avatar
He said he used LS3 springs,its confusing,seems the LS3 has 2 different sets,1 for auto trans (DOD?&VVT?) then a set a valve spring for manual trans,correct P/N would be great
Old Oct 19, 2011 | 10:27 PM
  #80
Area47's Avatar
ls3 manual. or get the ls9 springs. i prefer to match parts, but thats just me
the ls7 cam has a smaller base circle which will require longer push rods to get the valve train back in check.
