Ls9 Cam results, dang.
Old Oct 21, 2011 | 10:12 AM
  #91
hog's Avatar
hog
Originally Posted by TheBurlyMan
Why would this be a better bang for the buck than the LS7 cam? I thought the LS7 cam would only require the same changes and work just fine. I ask this because based on these awesome results I was going to get the LS7 cam because the duration is a little larger and LSA angle a bit more narrow. (hopefully moving the torque band down in rpm's slightly)
Duration is the same between the 9 and 7 cams.
peace
Hog
Old Feb 2, 2012 | 04:10 PM
  #92
forklord's Avatar
hey just wanted to check in and see how that cam is treating you OrangeChevyII or if anyone else has tried this?? I'm really thinking about doing it soon! best bang for buck for a daily driver i figure.
also wondering if the 2011 L9H has "VVT" or anything that will get in my way?
Old Feb 2, 2012 | 04:34 PM
  #93
BrutalSierra's Avatar
L9H is the VVT version of the L92.
Why not get a VVT cam?
Old Feb 2, 2012 | 04:43 PM
  #94
forklord's Avatar
sure, i just didnt know if it was vvt or not plus this setup is cheap. what do you suggest? i have a blackbear tune already and custom catback. gonna get obx LT's, M.I.T, a cam and then retune. 400rwhp is plenty for me. also, i want more low-mid torque. might do some small camper/trailer hauling and rubber burning already got the 3.73 towing package
Old Feb 2, 2012 | 05:12 PM
  #95
62nalide's Avatar
ive had both vvt and ls9 cam now but the ls9 i like with boost but the vvt cam was a great i did 422rwhp and 417rwtq with a vvt cam and really great mpgs
Old Feb 2, 2012 | 05:27 PM
  #96
forklord's Avatar
what are the cam specs or what specific one did u use for VVT to make that power...and what other mods did you need to make the cam work. thanks!
Old Feb 2, 2012 | 08:29 PM
  #97
62nalide's Avatar
no too sure on the specs ill try to find my index card but I had Pacesetter long tubes 1 3/4, 160* stat, CAI, 3 1/2'' exhaust, springs, and Dyno tuned
Old Feb 2, 2012 | 08:58 PM
  #98
forklord's Avatar
you only needed to upgrade springs in the valvetrain to make the cam work? i want to know more! brand and part # pls and thank you!! not many performance shops around here to help...
Old Feb 3, 2012 | 12:18 AM
  #99
rjwz28's Avatar
Man Motor club
Old Feb 19, 2012 | 02:27 PM
  #100
NemesisC5's Avatar
Is L9H the code for the LS9 cam? I thought LS9 is VVT and that the VVT was a contributor for the OP's 100hp increase above 5200rpm. I'm researching cams and would like to get my facts straight. It seems like the VVT technology is a move in the right direction for power & fuel mileage.
I talked to Competition Cams and they have a couple offerings in VVT, any info will be appreciated.
Thanks !
