Long tubes or torque converter?
Starting to look into the converter. I think since this is my daily driver that a 2600rpm stall (or close to that would be best). I think 3000-3200 will be too much.
Question: My transmission doesnt feel the greatest. Is it best to have the trans rebuilt at the same time? Maybe throw in a vette servo and a shift kit. I know if the trans grenades with a new converter in it then the new converter will be toast also.
Whats the scoop on the TBSS converter?? Can i buy a new one? used one? stall ratings?
Man Ive got a 13 gmc ext cab 6.2, with a tune and a cai it went the best of 8.96 in the 1/8, I put on some AR headers a couple of weeks ago and the best now is 9.13, ok I put some 22's on at the same time but the weight of the 22's were just 10lbs heaver than my stock 20's so I thought no big deal but now I wonder, any way kind of got off the subject but the truck feels stronger threw the midrange for sure with the headers but it's a turtle down low, long story short my vote is for the verter first, I would have done it first but got a deal on the headers, I think that with the verter the truck would pick up 2-3 tenths, sorry for the rambling. THANKS!
TBSS stall would be equal to stock. A trailblazer 4.2L stall is the one that can flash to around 2400-2800 depending on power level. It will be very lazy in your truck compared to the circle d 3200 stall which will drive 98% like stock until you mash on it then it will give you the performance you want. It is the best of both world.
Gamble 686, do you have any track times before and after the verter,and is it the $500 one, I just got them to make one for my Ls2 69 Camaro, no track times but it feels a lot better, sorry to hijack the thread.THANKS!
6L80e
Circle D Specialties High Performance 278mm Torque Converter for GM 6L80 LS
4L60e
Circle D Specialties High Performance 278mm Torque Converter for GM 4L60 LS
Typical results swapping to a 3000stall will be around 1/2 to a full second in the 1/4 mile. Obviously a lot of other factors will make a difference. Either way I would recommend getting an aftermarket transmission cooler.
4L60e
Yes as long as you keep your temps down using a good trans cooler it should be just fine. Keep an eye on temps and you should be fine if you keep it reasonable. Trucool 40k is a popular choice.
BennyB
Aug 1, 2015 08:48 AM
Suburban2500
Jul 13, 2015 09:57 AM
