intake & tb questions
Old Oct 12, 2009 | 06:20 PM
FrankyRST's Avatar
Default intake & tb questions
are the new nnbs 5.3 intakes and/or throttle bodies different from the L92s or the tbss?
is it worth putting in either a L92 or tbss intake and/or throttle body in my 5.3?
thanks in advanced
Old Oct 12, 2009 | 06:24 PM
CI DENALI's Avatar
The L92 intake can't fit the 5.3. The L92 has rectangular port heads and the 5.3 has cathederal ports. From what I've read the tbss has a better intake than the 5.3 that should fit. I think the throttle bodies are the same on the L92 and the tbss (87mm). not os sure about the 5.3 though.
Old Oct 12, 2009 | 11:38 PM
FrankyRST's Avatar
Oww yeah thats right, the L92 is different
i thought all of the nnbs already came w the 87mm tb but wasnt 100% sure
so i guess the tbss intake is my only option
is there any proof or evidence (like a dyno comparison) that the tbss intake is better than the nnbs stock ones?
Old Oct 13, 2009 | 12:12 AM
iamkeniff's Avatar
upgrade to a 90mm, leave your intake alone, its actually the same as the TBSS....if i was you id get a p&p 90mm tb or spend the extra cash on a Fast tb or something of the sort...
i have a LS2 tb an 4" CAI on my 5.3 an it pulls a lot harder 4000rpm+
Old Oct 13, 2009 | 12:22 AM
lucky77's Avatar
Banned
TBSS and NNBS share the same intake+ throttle body (87MM) but with a slight port u got A 90MM / as for the L76 /L92 intake- it would NOT be a direct due 2 the rectangle head port (just like CI Denali ) said .. and 5.3 (l33,ly5,ect) have cathederal ports-
Old Oct 13, 2009 | 12:56 AM
FrankyRST's Avatar
Thanks guys
yeah i think ill just p&p my tb
u guys know if fast ever came out w the 102mm tb?
Old Oct 13, 2009 | 01:26 AM
lucky77's Avatar
Banned
yes F.A.S.T does have 102MM tb , but you also need a 102MM intake , which runs about 1K < a 5.3 with 102MM intake ( not a good idea) you need atleast a l76/l92/ls3 + a big Intake cam . . if not ur little engine is going 2 choke with that much Air..
http://www.fuelairspark.com/
Old Oct 13, 2009 | 04:11 AM
iamkeniff's Avatar
stick with a FAST 90mm, cam, Nitrous.
Old Oct 16, 2009 | 01:38 AM
FrankyRST's Avatar
If I ported my tb that would make it 90mm, right?
And what diffrence can I expect from ported heads and tb?
Old Oct 16, 2009 | 01:55 AM
lucky77's Avatar
Banned
P&P throttle body' you will feel a slight difference on throttle responce ..
and p&p head's WILL make a difference , espeacilly mid+top end < get a valve job while ur @ it..
