installing crank bolt?
Old Oct 16, 2012 | 03:00 AM
JCunningham's Avatar
Default installing crank bolt?
I will be pinning my crank on my 6.2L and wanted to know what is safe to lock the fly wheel to torque it down with a stock bolt. Im not paying $100+ for a Kent Moore tool. Should I put some APR lube on the bolt 1st or dry or lock tite? 37ftibs then 140 deg right?
Old Oct 16, 2012 | 05:24 AM
TXSZ66AVLANCHE's Avatar
I've never used any thread locker on the crank bolt, usually I just use my impact to tighten.
Old Oct 16, 2012 | 05:27 AM
dirt track racer 81's Avatar
+2 for using an impact.. I've reused mine countless number of times.
Old Oct 16, 2012 | 05:28 AM
03sierraslt's Avatar
I have always put my crank bolt in dry also. I have done the tq sequence a well as used a impact. Both worked fine, I can't say that I would trust a stock bolt with a impact, I've use it on ARP's. Stock torque to yield bolt is made to twist and don't like that combo with a impact gun. Just my opinion anyway.
Old Oct 16, 2012 | 05:53 AM
The only problem I've had with a crank bolt is when I forgot to install it lol, drove 7k miles without it! Thankfully it was a new crank and pulley, otherwise it probably would not have made it.
Old Oct 16, 2012 | 06:08 AM
Aw hell if it lasted that long, you don't need it. I bet you were a bit suprise when you found that.
Old Oct 16, 2012 | 06:31 AM
Heck yeah I was! Was finishing up replacing the ac compressor and when I went to put the skid plate on I noticed a hole in the center of the crank pulley. In the bottom drawer of my tool box next to the crank pulley puller and installer was the bolt still in the bag.
Old Oct 16, 2012 | 11:06 AM
so whats a safe way to lock the engine in place so I can use the torque method
Old Oct 16, 2012 | 11:12 AM
GMCtrk's Avatar
Wrap a serpentine belt around the crank pulley and the pulley by the ALT.
Old Oct 16, 2012 | 04:53 PM
iamkeniff's Avatar
i use a big *** prybar and lock the converter in the bellhousing
10 trucks done that way making 350rwhp+ and never had an issue
