Help guys 07 vortec max 2300 maggie wnt tune for 80lb inject factory ecm limits it 63
Old Aug 8, 2012 | 09:44 AM
NKPPhil's Avatar
FWIW Edelbrock says if you put their E-Force supercharger on an L9H you can't use E85 any more. I'm guessing the fuel pump/injectors/etc won't keep up with the extra volume of fuel to feed a blower with alcohol, even though it feeds the 6.2 just fine w/o the blower. Here's what the installation instructions say:
"91 octane or higher gasoline is required at all times. If your vehicle has been filled with anything less, it must be run until dry and refilled with 91 or higher octane gasoline twice prior to installation. Any failures associated with not using premium 91 octane gasoline or higher, will be ineligible for warranty repairs. THE FLEX-FUEL FUNCTION HAS BEEN DISABLED. DO NOT USE ANY GASOLINE WITH AN ETHANOL RATING HIGHER THEN 10% (E10). FAILURE TO DO SO WILL RESULT IN ENGINE DAMAGE AND VOID YOUR WARRANTY."
(Sorry about the shouting, that's Edelbrock's, not mine.)
Old Aug 8, 2012 | 10:01 AM
TX Tahoe Z71's Avatar
I'm running my bone stock flex fuel in-tank pump with a Kenne Bell Boost-a-Pump and it's keeping up with my 75# injectors and has been for a year or two. I run E85 about half of the time.
Go5.3tt06
Sep 12, 2015 09:29 AM
lxcoupe
Jul 21, 2015 02:12 AM
oharajo
Jul 18, 2015 09:24 PM
4B11T
Jul 13, 2015 03:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
