Has anyone installed
#21
You would want to go to the fuse block under the dash. This has multiple 12v main powersource options. You could hook up there and it is pulled straight from the battery in this location.
As far as my comment earlier.... whoops.... my badd friend! But your right everyone here should be double checking there work at home. Grab yourself a multi meter and start pinning out your sources!
#22
Question... When grabbing 12 volt ignition power when installing the the LC-1 and the gauge do I take power from the same wire/pin location? What size fuse should I run? Innovate says to use at least a 5 amp fuse for the LC-1 but if both LC-1 and gauge are mounted to the same ignition source what size fuse would I use? Innovate doesn't specify what fuse the gauge will need. I am assuming I will just tape up the yellow wire (analog out 1) for the LC-1 as the instructions said optional. the Brown (analog out 2) will be used with the white wire from the gauge.
Also what pin did you guys mount it to? I posted a pin location for the ignition source elsewhere but didn't get much feedback.
#23
any updates?
LCHEE
Oct 24, 2020 04:10 PM
GXPJAY
Nov 5, 2015 06:49 AM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
