Has anyone installed
Old May 20, 2010 | 05:52 AM
2007chevy5.3l's Avatar
Default Has anyone installed
A Innovate LC-1 wideband in their NNBS yet? Im trying to figure out where to grab a switched power source. Id like to have the gauge on only when the engine is running. Reason being I listen to my radio alot when the engine is off and the key is turned to the 1st click position. I just dont want my senson to be on all the time when the engine isnt running and reducing its life even more. Hope this makes sense and is all understandable.
Old May 20, 2010 | 07:46 AM
iamkeniff's Avatar
ive never seen a 12v power source for when ONLY the engine is running honestly.
if it's such a big deal but it's a pain in the rump, id run it to an ignition 12v and put a switch on it honestly.
Old May 20, 2010 | 05:51 PM
schino's Avatar
i dont know about on only. i did a lot of searching and the only real accessible places on my truck without cutting wires are some fuses in the under hood fuse box. i forget what they were for exactly but they were towards lower right corner and 10 amp. there is like 3 in a row atleast
Old May 20, 2010 | 07:08 PM
f4tal's Avatar
Dude really? I used to install stereo systems for a living, I could have def helped ya out hahaha. Its cool though i know you needed a free post
Hook it up to an ignition source an you should be good. I wanna say the orange or pink wire in the ignition harness under the steering column. Double check though, been a while since i worked on those
Any accessory source will still turn it on when listening to the radio.
Old May 20, 2010 | 07:19 PM
Three6GMC's Avatar
just tap into the fuel pump trigger wire on the relay i did that before but on a older 2001 truck you gunna have to pull the fuse box off to do it but its really easy
Old May 20, 2010 | 07:39 PM
Ohh crap sorry Alex! Ive been so caught up in parts and work and everything that you dealing with this sort of stuff totally slipped my mind. If ya want we can meet up this weekend and we can try to find a wire under the column.
Thats going to be my plan B if I cant find anything else
Old May 20, 2010 | 08:42 PM
Tootall's Avatar
uhm . . . cigarette lighter usually gets it's power from the ignition too.
Old May 20, 2010 | 08:56 PM
Theres power to it all the time. I have my radar detector plugged into it and its doesnt go off till i unplug it
Actually its a 12v outlet since the gmt900's dont have cigarette lighters/ashtrays
Old May 20, 2010 | 09:49 PM
schino's Avatar
now that i think about it.. the fuses under the hood that i mention do not have power with key to first click. where my stereo comes on and stuff but no dash lights but when you turn to second click it does get power. this may be what your looking for.
Old May 21, 2010 | 04:46 AM
Yes sir thats exactly what I need.
