Gear swap
Old 10-19-2018, 02:24 PM
Navi's Avatar
Default Gear swap
Finally getting around to changing my gears to correct for the oversized tires, got to thinking if Im going in for a gear change am I shooting myself in the foot for not putting in a tru-trac at the same time? Cant be much more labor?? Currently have the g80 which hasn't given me any trouble, but at 130,000 miles might be on borrowed time.
Old 10-19-2018, 03:18 PM
madmann26's Avatar
Labor rate would be the same.
In other words, you have to do the same thing to pull and put back a G80. Might as well do it with a TruTrac.
Old 10-20-2018, 02:39 PM
Burnett03's Avatar
Labor should be the same, they *may* charge a little extra to press new bearings on and check gear pattern. I suggest you go ahead and get the trutrac put in too.
Old 10-20-2018, 02:50 PM
ILuvJDM's Avatar
I don't see why they would charge any extra. They won't have to remove the old ring gear or remove the old bearings from the carrier. Pressing on new bearings is simple and maybe takes 5mins
Old 10-20-2018, 03:09 PM
Burnett03's Avatar
I don't disagree with you, but most shops aren't in it to do things for free. Ya pressing the bearings on is simple but they might still charge.
Old 10-20-2018, 03:16 PM
3wide's Avatar
If you are at 130K I would replace all my bearings at this time along with the True Trac-Gear Swap.
Old 10-22-2018, 09:26 AM
ILuvJDM's Avatar
Correct, but my point was they wouldn't have to remove the old bearings or ring gear. It would likely be no extra charge because you're saving them the time and effort of removing the old stuff. If a shop charges you more money on top of the cost for a gear swap, then I would look elsewhere
Old 10-23-2018, 06:37 PM
Drspencer's Avatar
I got a new TruTrac with bearings if you’re looking for one....
rossp
09-07-2017 10:54 PM
black00chev
05-26-2017 09:34 PM
AV8R27
10-10-2009 03:13 AM
CashDudeHomie
03-20-2008 12:01 AM
whoopassracer
11-15-2004 08:43 PM
Quick Reply: Gear swap
