Fast lsxrt questions
Old Sep 25, 2017 | 12:10 PM
Rip170's Avatar
Registered User
Default Fast lsxrt questions
I am planning on installing a fast lsxrt on my 08 silverado 6.0 cathedral port set up, after a lot of research I pretty much got it all down except for the fuel rails. I would like to run fast billet rails but not sure if I need to run a fuel pressure regulator, if so does someone have a pic of it or instructions on how to run one ?
Old Sep 25, 2017 | 10:20 PM
fctry286's Avatar
Your better off running a different manifold. Speaking from experience, I had nothing but issues with mine. Trying to get it idle correctly then it leaked. Just get a holley or edelbrock manifold
Old Sep 25, 2017 | 11:50 PM
Rip170's Avatar
Registered User
Dang , well I got it for a decent deal , was yours warped ? What other issues did you have ?
Old Oct 4, 2017 | 10:04 AM
darkirish63's Avatar
Never had an issue with mine - have the newer black version - install was done by my tuner and no idle or leak issues whatsoever.
Old Oct 4, 2017 | 05:27 PM
Rip170's Avatar
Registered User
Mine is a grey top but I put a straight edge across the intake ports and it seems pretty level
Old Oct 4, 2017 | 07:48 PM
Just make sure you replace the valley cover bolts with the round top ones provides in the kit & torque everything down as instructed and it should be fine. A tweak to the tune is an absolute need as well or it will feel like garbage.
Old Oct 4, 2017 | 08:21 PM
Rip170's Avatar
Registered User
how did your truck feel after the tune? Any noticeable difference up top and down low ? Also did you replace your coolant crossover ?
Old Oct 4, 2017 | 08:35 PM
2002_Z28_Six_Speed's Avatar
I had to bend the hell out of my crossover to get it to fit but factory one works. Barely. Not much clearance at all.
You don't need a FPR. Just put an adapter from the FAST rails to your factory fuel line. Probably something like -6 AN port adapter that comes in the kit to a straight -6AN fitting. To short piece of line. To a 3/8 male quick disconnect. Something like that. Then run a cross over on the front. The first time around I ran a cross linked synthetic line but I heard stories about it can rot out and then I switched to a PTFE line.
Old Oct 5, 2017 | 08:39 AM
Truck feels great after the tune - hard to really say if there was a difference between the TBSS I swapped out since the motor was fresh as well. PCM of NC sells a fuel rail cross-over for the LSXRT that works with the FAST rails if you're using them. I had them do the whole thing since they tune my ride as well. Happy with the whole set-up in the end.
Old Oct 6, 2017 | 05:39 PM
Rip170's Avatar
Registered User
does it matter if the crossover is in the rear or the front ?
