factory lift block on a 2WD?!
Old Jun 30, 2011 | 02:09 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default factory lift block on a 2WD?!
just looking under the truck a little while ago and noticed that this thing has a lift block in it like a Z71... WTF!!
Looks like shackles and removing this block should put her sitting nice and level
Old Jun 30, 2011 | 03:15 PM
redneck08sierra's Avatar
yep, can't believe you didn't notice before!!! I believe there are enough threads on the shackle to take out the block and tighten down
Old Jun 30, 2011 | 03:32 PM
Hunt&Fisherator
yeah, only had the truck a few days. news to me. I'm plenty familiar with GM truck suspensions and how to alter them.
Old Jun 30, 2011 | 05:11 PM
Not really related to your post but this is the reason I opted for the 2WD since they sat as high as the 4WD. Unlike in the past where the 4WD was always a bit taller. Post pics when finished!
Old Jun 30, 2011 | 06:32 PM
dlt76028's Avatar
lol, you got to keep up to date with these new trucks man.
Old Jun 30, 2011 | 09:20 PM
Hunt&Fisherator
I've been under several but for some reason never noticed. I took mine out today, looks much better and didn't affect the ride at all, shackles would level it perfectly. Not gonna mess with the suspension past this most likely, it's gonna get tinted, maybe a muffler and left alone.
Old Jul 1, 2011 | 09:29 AM
dumb question but when you took the blocks out, what part of the truck did you jack up to get the leaf spring off the block? Also, no issues with the u bolt threads
Old Jul 1, 2011 | 07:04 PM
dlt76028's Avatar
jack up the truck under the rear differential, put jack stands under the frame, lower jack down until differential stops. now all the tension is off the leaf springs.
Old Jul 1, 2011 | 08:28 PM
Hunt&Fisherator
Drove it up on a 4post lift, used the jack built in the lift to pick the truck up by the frame. Let the rear hang, busted the U bolts loose with an impact, popped the blocks out, lowered the truck with the jack until it rested on the axle, cinched up the U bolts and away we went... Took all of 10min tops... But yes, I cheated
It could be done in a driveway with hand tools and jack and jackstands in 30-40 min easily.
signguy62
Sep 20, 2015 02:05 PM
1bad2k
Aug 18, 2015 09:50 PM
LoneSStar
Jul 27, 2015 09:27 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
signguy62
Jul 16, 2015 05:43 PM
