factory lift block on a 2WD?!
just looking under the truck a little while ago and noticed that this thing has a lift block in it like a Z71... WTF!!
Looks like shackles and removing this block should put her sitting nice and level
I've been under several but for some reason never noticed. I took mine out today, looks much better and didn't affect the ride at all, shackles would level it perfectly. Not gonna mess with the suspension past this most likely, it's gonna get tinted, maybe a muffler and left alone.
jack up the truck under the rear differential, put jack stands under the frame, lower jack down until differential stops. now all the tension is off the leaf springs.
Drove it up on a 4post lift, used the jack built in the lift to pick the truck up by the frame. Let the rear hang, busted the U bolts loose with an impact, popped the blocks out, lowered the truck with the jack until it rested on the axle, cinched up the U bolts and away we went... Took all of 10min tops... But yes, I cheated
It could be done in a driveway with hand tools and jack and jackstands in 30-40 min easily.
signguy62
Sep 20, 2015 02:05 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
