Electrical issue - cluster lights up, that's it
Old Mar 24, 2019 | 06:17 PM
Jaxon's Avatar
Default Electrical issue - cluster lights up, that's it
I bought an 07 Silverado as a non-runner. The truck has super low kms, but I can't get it to start. Battery is good. When you turn the key on, the ABS / Engine lights come on. About 5 seconds later the rest of the cluster lights up. When you turn the key to start, nothing happens. I can move the shifter without pushing the brake. The range does not show what gear it is on the dash. The signals don't work, high/low beams don't change, wipers only work on high. Horn works. No interior lights, no 4 way flashers. Radio and heater work. I've wiggled wires under the dash, tested the mega fuse, checked the big spade connector under the engine fuse block, ran a new ground to the engine and to the cab. Nothing. Any thoughts?
Old Mar 25, 2019 | 01:19 PM
terravast4's Avatar
where did you buy it? Maybe this is a flood vehicle.
Old Apr 3, 2019 | 10:34 PM
Jaxon's Avatar
For anyone who has similar problems, turns out it was the BCM. I replaced it with a used one, and it fired right up.
stoicho315
Feb 3, 2014 08:47 PM
Nick™
17
Feb 8, 2013 11:31 AM
jakebdb56
May 1, 2009 11:43 AM
fastgmc53
Mar 25, 2009 08:15 PM
TG02Z71
Apr 12, 2006 10:24 PM
