Help, Truck won't start, electrical issue.
Old Apr 12, 2006 | 08:38 PM
TG02Z71's Avatar
Default Help, Truck won't start, electrical issue.
I was just changing the switch for my boost controller and forgot to disconnect the negative terminal first, now it will crank but the fuel pump is not comming on and the fuel gauge as well as a couple others don't move but still illuminate?
The security light in the message center flashed a few times , but I thought that was normal.
Been pulling fuses and checking a couple with a continuity tester and see that the fuel pump fuse does not show continuity, neither does another fuse.
Left my damm meter at work.
HELP please!!
I know it has to be something simple. DOHHH!!
Old Apr 12, 2006 | 08:46 PM
dewmanshu's Avatar
Moderately Differentiated
Uhm, no continuity means blown fuse. Replace the fuse(s) that don't have continuity!!
Old Apr 12, 2006 | 08:52 PM
TG02Z71's Avatar
These are the large block type fuses for the fuel pump and the daytime running lamps. I'll check a couple more on accesories that still work to see if they have continuity.
Old Apr 12, 2006 | 09:04 PM
TG02Z71's Avatar
The horn works and that fuse does not show continuity either, they must be switches/relays not fuses.
Anyway I found the bad fuse, it was the (ECM B-20amp) just to the left of the (F/PMP) relay or whatever the hell those things are.
It all works fine now, thank god!
Old Apr 12, 2006 | 09:18 PM
TIM Z's Avatar
11 sec. Truck Mod
Glad to see your going to be able to sleep tonight!!!
Old Apr 12, 2006 | 09:33 PM
TG02Z71's Avatar
Thanks, I'm soo freaking releived right now. Starting pulling out all the test equipment for a night of serious horseshit!
What the hell does a (ECM B) fuse do anyway???
Old Apr 12, 2006 | 10:24 PM
RoninsDenali's Avatar
ECM B, as far as i can remember powers the PCM (in conjunction with PCM 1) as well as the fuel pump itself. Atleast i remember someone saying the fuel pump. I'd check my wiring diagram, but its in my truck and its raining out
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
