Damn you GM
Old Aug 21, 2009 | 01:00 PM
Beyond Static's Avatar
Default Damn you GM
GM changed up pinion bearings on the '09's. 07-08's are the same, but 09's take a bigger bearing. Got the rearend pulled apart, new ring gear bolted on, and went to test fit the pinion bearing race into the diff, and it's 1/2" too small. Not a dealership in town has the part, and the closest place to get it is Michigan at the manufacturing plant What the hell do I do now
Old Aug 21, 2009 | 01:06 PM
mwbrannen's Avatar
haha damn that sucks.. good lookin truck though
Old Aug 21, 2009 | 02:21 PM
00ChevyScott's Avatar
Wearin' da big hat
Steal one off another truck!
Old Aug 21, 2009 | 03:07 PM
CharlyNali6.2's Avatar
f awk that is pretty gay!! id be pissed.
Old Aug 21, 2009 | 04:01 PM
Randy's Ring & Pinion ended up having a set at their Tennessee warehouse. Said it should be here tuesday.
2HighN2FlyZ71's Avatar
just went threw the same thing mine came from DT COMPONENTS the PART # is STA 4195
the bearing was 45 bucks so good luck i had mine overnighted
Old Aug 21, 2009 | 08:32 PM
skipperdaddy's Avatar
damn! that sucks! glad you posted this though... ill keep that in mind when i get some gears! thanks for the good info!! nice truck you got there!
Old Aug 21, 2009 | 10:42 PM
2005 Silverado's Avatar
SPAM HUNTER
you could press the one off the old pinion.
Dustin
Old Aug 22, 2009 | 12:20 PM
I thought about that, but was worried with all the beating it took to get the pinion gear off the bearing might be shot.
Old Aug 22, 2009 | 01:15 PM
i took mine to the local powertrain store and they pressed my factory bearin off after i done frigged it up tryin to get it off it would have saved me a 100 bucks if i would have just took it to them to start wid but i thought a 10k press could do it but i was wrong lol
