Catch Cans Again
Old Feb 8, 2013 | 11:11 AM
  #81
RacinRust's Avatar
What about off of the master cylinder mount? That's really close.
Old Feb 8, 2013 | 11:34 AM
  #82
ak2007r6's Avatar
I was thinking this also. Was gong to call Mike Norris next week and see what he recommends for my setup. See if I can get away with one or if I should run two.
Probably mount one like zachm89 did and the other to the master cylinder or something close by.
Old Feb 8, 2013 | 02:18 PM
  #83
TIM Z's Avatar
11 sec. Truck Mod
Let us know what you find out
Old Feb 8, 2013 | 03:16 PM
  #84
RacinRust's Avatar
Wonder if he makes a double mount for two cans?
Old May 2, 2013 | 09:04 AM
  #85
Choda's Avatar
For you FI guys, did you put a check valve in the hose going from the intake to the can? Keeping boost out of the catch can and away from the pcv valve?
I have a check valve in the stock line but I am also getting some oil in my intake and ordering up the Mike Norris can.
Old May 2, 2013 | 09:21 AM
  #86
ak2007r6's Avatar
When I talked to Mike he recommended using a check valve. This was his response for me.
In most cases a single catch can on the PCV hose is enough, but on a boosted application and if the engine is built "loose) then a second can on the breather may be needed. Just hard to say for sure. Just be sure to have a one way check valve in the PCV hose so boost does not get pushed into the crankcase that way.
Hopefully pick one up in the next couple weeks if I can convince the wife to let me spend more on the truck.
Old May 2, 2013 | 09:30 AM
  #87
Smokymance's Avatar
I dont have a check valve on mine, maybe i should look into it...
Anyone has a link to one?
Old May 2, 2013 | 09:36 AM
  #88
Choda's Avatar
somewhere on here I seen really nice black ones that had a arrow on them.
looked like alum AN fittings but were check valves.
dont think they had threads or anything, prolly push lock, or barb.
Old May 2, 2013 | 10:17 AM
  #89
ak2007r6's Avatar
I know the Procharger kit when I installed it had one. It's in the line from the top of the manifold to the drivers size valve cover.
Old May 2, 2013 | 10:26 AM
  #90
Smokymance's Avatar
Got to find me one of those for the maggy
