Another one piece driveshaft on a CC-NNBS goes Boom
#31
The aluminum is just for show we all know the cardboard does the structural work on these trucks that's why we can't keep driveshafts in them.
I had a local shop build a high speed balanced steel drivershaft with OE ujoints for my truck It was 450 and I've had it to well past 100 and shes smooth as glass.
#32
but i dunno .. Maybe the techs knowEdit: just googled it lol : Figure 6-6).
To reduce the effects of vibrations and the resulting noises, manufacturers have used vari- ous methods to construct a drive shaft. An example of this is a drive shaft with cardboard liners inserted into the tube, which serve to decrease the shaft’s vibration by damping the vibrations.
Drive shaft performance has also been improved by placing biscuits between the drive shaft and the cardboard liner. These biscuits are simply rubber inserts that reduce noise transfer within the drive shaft.
#34
Edit: You can see in the first picture, there are tags of some sort at the end, 2 of them. Maybe there's some identifying information on them? I see them at both ends. I also see something similar on the 5" Driveshaft Specialties shown in post #6. Fairly certain it's not aluminum but now I'm curious if it is aftermarket
#35
It goes tink like steel and sure don't look aluminum. I bought the truck used but from dealer and it was unmodified.
http://i600.photobucket.com/albums/t...ps33bdeca7.jpg
http://i600.photobucket.com/albums/t...psf6949b04.jpg
#36
Looks like a steel one to me
Putting a magnet will def kno if its steel but its rusty like one
#37
kc kid. they stop doin steel ds's well before the 07's came out. thats not a stock one.
tiff. pull the trans and check the case for cracks. when i lost my second ds i had to get a new case and a host of internal parts that were bent and burnt up. trans temp sky rocketed and burned up some stuff. just an fyi for ya. then again, mine put a hole in the bottom of the cab and put a hole in the flex pipe as well.
#39
#40
better to get everything checked vs finding out the hard way.
