Another one piece driveshaft on a CC-NNBS goes Boom
To the OP you sure did blow that thing that apart! and I bet the wife did freak. Mine freaks at higher speeds let alone a grenade going off under the truck haha
I took a look at their site and those prices are better then I thought for a custom shaft. And with 4.10s plus speed limiter removed I better start budgeting
Keep us posted on the progress. Hope the trans tail shaft housing can be replaced without further trans problems. I was thinking a 2 piece steel shaft for replacement but I've been told the larger one piece aluminum with 1350's and balanced is working out ok.
I'm sure the steal would hold up a little better than the aluminum but I wouldn't push it. You can get a 2 piece out of a OBS and swap that in. The aluminum DS is big for nothing and is as thin as a coke can
