6L80 & 6.2 shifts?
Old May 11, 2012 | 09:08 PM
2012NUTCRACKER's Avatar
Registered User
Default 6L80 & 6.2 shifts?
Just wondering how others trucks shift after a tune? Mine will chirp the tires on the 1-2 shift at 3/4 throttle and catch a hard 2nd under full throttle.
Thanks
Old May 11, 2012 | 11:17 PM
Byrdman11's Avatar
Same. But has a funny delay between shifts.
Old May 12, 2012 | 05:39 AM
chanin6929's Avatar
The 6L80 is very different from the 4L80...my 4L80 would hit hard in every gear, where as the 6L80 seems to need a little more time to catch the gear...1-2 shift is really solid and will give me a good bit of wheel hop at WOT...the 2-3 however is delayed, but then the 3-4 will hit hard too...this seems to be the norm with the 6spd...I have a couple buddys with them and even with different tuners we all shift the same...
Old May 12, 2012 | 10:57 AM
iamkeniff's Avatar
Better be careful with that wheel hop on the shifts, you'll break internal parts.
Mine use to shift like yalls, now its a crisp shift with very little delay every shift. Also no chirping the tires, which is a plus for me. If your truck is banging the gears, chirping the tires....you are loosing time on your e.t
Old May 12, 2012 | 11:24 AM
Area47's Avatar
what he said.
mine on the 1-2 has a very slight firmness. the rest shift like stock at part throttle.
if i hammer it from a dig in first, it will spin through first, hit second, and keep spinning till i let off it.
an actual race from a dig, it will chirp the 1-2 and keep going. the 2-3 is assertive, but not hammering.
zero delay.
Old May 12, 2012 | 12:11 PM
Registered User
My shifts are not delayed at all and I have never gotten any wheel hop on the street or track.
Old May 12, 2012 | 12:57 PM
11Silvy's Avatar
Chirping tires and what not is not good for that stock tranny!
Old May 12, 2012 | 01:05 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Any chance you use HPT and would share your tune file? I'm having a hard time figuring out what works & what doesn't with these 6L80e's.
Old May 12, 2012 | 01:54 PM
iamkeniff's Avatar
I do use hpt, but you'd have to PM area47 bc he is the master mind behind my tcm tune
Old May 12, 2012 | 01:56 PM
iamkeniff's Avatar
The fastest delay ive seen on every 6L80e ive scanned including mine is .04 shift time. Id think any faster it wouldn't allow the clutches to release/engage in a safe manor. Just my .02
