2011 brakes suck! Options?
Old Apr 20, 2012 | 10:41 PM
  #31
Taubr Unit's Avatar
Oh ok, not a bad option either, i can see the bigger rotors and some Hawk pads be a pretty good upgrade?
Old Apr 21, 2012 | 08:09 AM
  #32
The biggest issue with GM's rear disk setup was the parking brake shoes that would break loose. That is why they swapped back to drums. I doubt it had anything to do with more surface area or actual durability of the disk brake system. I'm sure they just got tired of having to do warranty work to install the updated clip to hold the parking brake shoes right.
You don't live in the salt belt, so you wouldn't have seen the numerous issues with the half ton GMT800 rear discs. They were a constant issue. Pads would wear out in 30k miles, drag, squeal, warp, etc. All from salt spray/rust. Once they switched to drums, there were no more issues from the rear.
As for the stock brakes fading from a 120mph run...It is a truck that weighs 5000+ lbs. It is not a sports car.
Old Apr 21, 2012 | 10:04 AM
  #33
Robert91RS's Avatar
I would recomend a set of EBC rotors up front first and see if that solves the warping and fading issues. The front brakes really are pretty good outside of those issues and I doubt the rear drums are holding anyone back much.
walledition
Feb 24, 2026 03:27 PM
carid
Oct 28, 2015 08:24 AM
Noah Burns
Sep 13, 2015 09:28 AM
InsaneDomestics
Sep 7, 2015 09:19 PM
Alco
Sep 4, 2015 04:08 PM
