2011 brakes suck! Options?
Old Apr 19, 2012 | 08:02 PM
Taubr Unit's Avatar
Hahaha, classic
Old Apr 19, 2012 | 08:15 PM
TX Tahoe Z71's Avatar
Hydroboost swap? Cheap and effective.
Old Apr 19, 2012 | 08:46 PM
07ccz71's Avatar
Don't know if hydra boost will work on nnbs, I don't know why, but nobody has done it that I've seen on here or any other site I frequent
Old Apr 19, 2012 | 09:29 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Im picking up a Vmax on Saturday, Ive also got a hydroboost setup sitting on the shelf
Old Apr 19, 2012 | 10:00 PM
Didn't know that
very nice
Old Apr 20, 2012 | 01:38 AM
Originally Posted by MyLS1Hauls
So your issue with them has nothing to do with function, just opinion? The GMT900 brakes are the best yet. My 6.2 truck has rear disc and I dont think the pedal feel is as good as an equivalent 5.3 truck with drums.
GM had a bunch of issues with drums on the older 800 trucks. They went back to drums in '05, and haven't had any issues since. They work, require less maintenance, and are less expensive.
If you're not doing 100mph+ runs on the freeway with heavy braking, the stock brakes are fine. I do prefer pads that are a bit more agressive, however. Also, you won't gain anything by installing stock replacement slotted/drilled rotors on the front. They just reduce pad contact area.
I will disagree. My '09 5.3 truck with drums in the rear always had a "soft" pedal feel I found lacking. When I took my '11 6.2 w/ the 14-Bolt rear and disc brakes on a test drive when I was buying it the FIRST thing I noticed was the brake pedal feel and how much better it stopped.
Old Apr 20, 2012 | 05:50 AM
iamkeniff's Avatar
mine are stock replacement rotors, and the braking is a ton better than a stock rotor. ive had plenty of 110mph to 10mph slow downs at the track with these things. no warping or anything and i have 10k on them *abusive 10k at that* my stock rotors showed signed of warp within 8k and was complete crap!
Old Apr 20, 2012 | 06:00 AM
rjwz28's Avatar
Man Motor club
Yeah 91Z28, same here.
OP, why did you get a $35k truck with drum brakes if you wanted discs? I've got a 2011 with four-wheel discs, and it didn't cost more than $35k.
Old Apr 20, 2012 | 08:17 AM
Robert91RS's Avatar
My brakes are WAY better than any GMT800 I have ever driven.
I posted a parts list for the hydroboost conversion. Just waiting for somebody to man up and try it.
Old Apr 20, 2012 | 09:04 AM
rcsb jon's Avatar
GM went back to drums on the rear due to:
-more surface area v. disks (a.k.a they work better)
-better durability v. disks (gmt800's had numerous rear disk issues)
